Question about Kodak EasyShare Z712 Digital Camera
Hi, I have a Kodak EasyShere canera, model # Z712 IS. I used to be able to take hundreds of pictures before the memory was full on this camera. Now it says it's full after 14! How do I correct this problem? Mark
    Brigadier General:
  • 11,967 Answers
Somehow, you started using the camera's internal memory which is very small. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Posted on Mar 23, 2011
How do I unload internal memory
How do you usually transfer pictures from the camera to your computer?
If you use the USB connection, remove the memory card before making the connection. If you put the memory card into a card reader, copy the pictures to the card following the instructions on this page of the user guide.
Mar 05, 2013 | Kodak Easyshare Z712 Is 7.1 Mp Digital...
How do I move from full internal memory to memory card
Make sure you have the card installed in the camera. Press the Review button, then press the Menu button. Use up/down to highlight Copy, then press OK. Use up/down to highlight Memory Card or Internal Memory, then press OK. Use up/down to select an option, then press OK.
May 17, 2010 | Kodak EasyShare Z712 Digital Camera
How do I transfer pictures in the Internal memory to a card?My canera is a Kodak EasyShare Z1485 IS
First, make sure you have a card installed. Press the Review button, then the Menu button. Use up/down to highlight Copy, then press OK. Use up/down to highlight an option, then press OK.
May 13, 2010 | Kodak EASYSHARE Z1485 IS Digital Camera
I have a Kodak EsasyShare Z712 IS. I
If you have a PictBridge-compatible printer, you can simply connect the camera to the printer using the USB cable.
Alternatively, you can copy pictures from the internal memory to a memory card. Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Continue on to select your desired options.
Mar 24, 2010 | Kodak EasyShare Z1275 Digital Camera
Z712 IS screen is white & blue with horizontal & vertical lines
It is not possible to buy a viewing screen for KODAK cameras.
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Feb 03, 2010 | Kodak EasyShare Z712 Digital Camera
I have Kodak EasyShere V1223 It won,t Turn on, Go
Here are the steps for V1223 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare One Digital Camera
I Have the Problem with my Easyshare Z712 IS Batteries
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
3. Without the memory card,turn on your camera.
Contact KODAK:
Dec 03, 2009 | Kodak EasyShare Z712 Digital Camera
My Kodak EasyShare Z712 IS problem is with the batteries. I'm using the Kodak Digital Batteries and they will only last about 30 minutes..even when I just use the viewfinder instead of the LCD. My son can...
I've had the exact same problem with mine. My wife was ready to buy a new one, but I didn't want to giveup the nice optical zoom on the Z712 IS. Checking out the web and a friend of ours with the same camera, it appears to be a common problem. My last time to try the camera, I took 19 pictures on brand new batteries and they died. The Kodak site doesn't really acknowledge a problem with the camera, but I found the latest firmware (1.06) and just walked around the house taking pictures with flash. At 25 pictures, I'm still going strong. Definitely worth a try to see if it fixes your problem: http://www.kodak.com/global/mul/service/downloads/DownloadFile.jhtml?locsvcsEntryPath=10807&product=EKN033025&operatingSystem=windows_xp&lang=en&type=firmware&downloadId=dln00179_file1&variant=false&pq-path=14091
Jul 12, 2009 | Kodak EasyShare Z712 Digital Camera
Interanl memory is full
I had this same problem. Go to menu then arrow to the right to access the tools. Scroll down to image storage, if like mine it was on internal memory, to fix it press the OK button and switch to auto. Then it will ask if no memory card in camera use internal memory continue will be highlighted, press OK. Hope this helps someone i searched the internet for a solution and just accidentally solved this problem by searching the cameras menu.
Nov 24, 2008 | Kodak Cameras
Battery problem
For my Z712 I'm using since one year CRV3 li-ion rechargeable.
No problems until now, few THOUSANDS of photos.
I've buy it from ebay.co.uk .
Regards.
Oct 06, 2008 | Kodak EasyShare Z712 Digital Camera
Kodak EasyShare Z712 Digital Camera Logo
85 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
