Question about HP OfficeJet 6210 All-In-One InkJet Printer
Bottom of fonts is missing
When i print, bottom of font is missing on all lines.
    Novelist:
  • 180 Answers
Try to check the print preview of the document your trying to print.
Posted on Aug 04, 2008
Need game instructions for "Who's
I believe you can download the directions for the game here
www.ciudadaventura.net/teachers/docs/guide_unit2.doc
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Courier New"; }@font-face { font-family: "Wingdings"; }@font-face { font-family: "Calibri"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 10pt; line-height: 115%; font-size: 11pt; font-family: Calibri; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }ol { margin-bottom: 0in; }ul { margin-bottom: 0in;
Aug 18, 2011 | Toys
Tip
How To Remove and Install a MAP Sensor for Your 1988 Dodge Aries
REMOVAL & INSTALLATION
Chrysler Electronic Fuel Injection (EFI), Multi-point Fuel Injection (MFI) and Eagle Throttle Body Fuel Injection (TBI) Systems
  1. Disconnect the negative battery cable.
  2. Unplug the electrical connector from the sensor.
  3. If so equipped, disconnect the vacuum hose from the sensor.
  4. Remove the MAP sensor mounting fasteners.
  5. Remove the sensor from the vehicle.
To install:
  1. Install the MAP sensor into its position and secure in place with the mounting screws. Tighten the screws until snug.
  2. Connect the vacuum hose, if so equipped.
  3. Plug the electrical connector back into the sensor. Make certain that the connector is clean and snug fitting.
  4. Connect the battery cable.
on Nov 22, 2011 | 1988 Dodge Aries
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
Printing envelopes from stamps.com from the MP tray on a Canon Imageclass 4350d - after printing I get a message asking "use current size". If I say yes it prints again, if I say no it prints again.
This can likely be solved with one of the following solutions.  If these do not work, please feel free to contact me at social(at)stamps.com. Thanks! This can likely be solved using one of the following solutions. If these do not work, please feel free to contact me at social(at)stamps.com.
1) Change the Printer Options - Enable L90 Only
2) Set Paper Feed to "MP Tray" and Change Printer Options to Enable EF only
3) Change paper size on printer to "B5"
Thanks!
Chuck
Stamps.com
!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-alt:"Calisto MT"; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-alt:"Century Gothic"; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} @font-face {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:modern; mso-font-pitch:fixed; mso-font-signature:-1610611985 1073750091 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} p.MsoPlainText, li.MsoPlainText, div.MsoPlainText {mso-style-noshow:yes; mso-style-priority:99; mso-style-link:"Plain Text Char"; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.5pt; font-family:Consolas; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} span.PlainTextChar {mso-style-name:"Plain Text Char"; mso-style-noshow:yes; mso-style-priority:99; mso-style-unhide:no; mso-style-locked:yes; mso-style-link:"Plain Text"; mso-ansi-font-size:10.5pt; mso-bidi-font-size:10.5pt; font-family:Consolas; mso-ascii-font-family:Consolas; mso-hansi-font-family:Consolas;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} -->
Aug 25, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Fonts not installed
Fonts are typically available either for free or for a fee.
Only fonts that are visible in your C:\WINDOWS\Fonts Directory will be available to print.
You can google fonts and find more if you are looking.
Also, depending on the program you are using, you can save as a .pdf to print and this will "pack " you fonts into the document. You cna also use the "prepare for commercial printing" option in MS Publisher to store the fonts in the file.
Bottom line, if the font isnt installed, you cant use it.
You may be getting this error if the document came from someone who has the font but you dont. If that's the case, tell your friend you need the fonts. Just copy them out of the E:\WINDOWS\Fonts directory to your disc.
That should do it.
Jan 13, 2009 | Canon ImageClass MF5770 Laser Copier...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
154 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
