Question about Philips GC 3112 Iron
Keeps tripping the main electricity on 20A breaker with no lead or bad connection. Advice?
    President:
  • 2,080 Answers
Perhaps you simply have too many power consuming items on that one circuit.
Posted on Mar 23, 2011
  • Joe2
    Joe2 Mar 23, 2011
    Check what other aplliances are powered by that one breaker circuit. If you have a refrigerator, freezer, television, microwave etc... all on the one circuit, and they are all running at the same time then that is probably too much current draw for that breaker. Try plugging in the iron to a different plug which is on a different circuit. If it blows that second circuit breaker as well, then you can be pretty certain it is a problem with your iron. Good luck.
Rotary iron kenwood used
If there are wires connected to the foot pedal, control is electrical, not mechanical. Contact eBay directly for resolution.
May 09, 2017 | Irons
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
My Iron keeps tripping the fuse in main power box what is causing this it doesn't happen with any other appliances?
Tripping the breaker or fuse as you call it is caused by excessive current draw. These are safety devices that are meant to protect from electrical overloads and fires. More than likely your iron has a failing heating element and should be replaced. If it is a steam iron it is also possible that it has developed an internal water leak causing a short. Continued use is unwise and a potential safety hazard.
Feb 19, 2015 | Irons
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
Our philips iron keeps tripping our fuse box - this is the second model (but different model) that has done it - is there any advice you have as to why this keeps happening?
Your circuit is bring overloaded by the iron.Irons use lots of energy They usually use more than half the capacity of most electric circuits.Try it on another circuit or unplug some other heavy energy user on the circuit.Better yet have an electrician have a look on the circuit.
Feb 13, 2011 | Philips Irons
Steam iron trips the main fuse
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Sep 07, 2009 | Philips HI-296 Iron
The ps 300 will not heat although the on light is on
I bought one of these units at a Salvation Army Store still in the box brand new. I experienced the same problems (power was lit, but the breaker would trip and turn unit off). I opened the unit up and since I have knowledge of circuits, I bypassed the breaker (trips when it reaches a predetermined temp). I did however add a CRUCIAL electrical component that makes this possible an keeps your house from burning down - a added a simple dial thermostat (like one from a single electric plug-in coil stove top). Bottom line, I took on this project moreless for fun and I would NOT RECOMMEND anyone try this unless you have some knowledge about electrical circuits.
Feb 18, 2009 | Homedics PS-200 Iron with Auto Shut-off
General electric light 'n' easy iron tripping safety switch
it is shorting out and tripping the breaker either from moisture or problem insulation
the cost to repair is more than a new iron so junk it and be safe
Jul 12, 2017 | Irons
Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Jan 26, 2009 | Tefal UltraGlide plus 1656 Iron
I plugged the iron on power and it tripped the circuit breaker
check the plug and make sure all connections are secure
check/replace the lead
or finally replace the element
i hope this helps in some way
Dec 23, 2008 | Irons
Philips GC 3112 Iron Logo
200 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
