Question about Apple Customized 15" MacBook Pro Laptop Computer Notebook
The disc will not eject from my apple mac? why?????? The eject symbol comes up but the cd stays inside? HELP?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and ise the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Posted on Mar 23, 2011
Testimonial: "Thanks a mill the reboot holding down the trackpad worked!!! Thanks a mill!!! Was getting worried!!!"
What key do iuse to eject a disc from my apple computer
On my MacBook Pro.
Here are the ways that I know.
The EJECT symbol looks like an arrowhead with an underline underneath.
Look for a key with the symbol on the upper right of the keyboard.
Go to FINDER and look for DEVICES. The DVD Drive should be listed and there should be the EJECT symbol after it and click it.
From the desktop, drag the DVD to the TRASHCAN.
Jan 25, 2015 | Apple MacBook Laptop Computer Mac...
I have macbook i can not eject the cd from laptop
Do you just want to remove the disc or fix the issue with not been able to remove from the computer?
To remove the disc try going to finder, one is display you should be able to see an icon that looks like a disc. Next to it there should be an eject icon, click the eject icon and your disc you come out.
Mar 12, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How to eject disc
Go into All My Files. On the left, go down to Devices, and click the eject symbol on your cd. Hope this works...
May 12, 2013 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Stuck dvd in my imac
If you're trying to eject a CD or DVD:
  • Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
  • If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
Jan 16, 2013 | Apple iMac G5 Desktop
I have a cd stuck in my laptop computer. It's a iBook G4. The cd tray doesn't come out. there is a mechanism that helps to push the cd out. I dont know the best way to get it out. Please help!! E
Option 1:
If you restart the computer and just after it restarts if you hold down the eject key on the keyboard it should eject the disc, if not I would check to see if there is a tiny hole on the disc drive that you can stick a paper clip in - not sure if the ibook will have it but worth while checking.
Option 2:
1. Restart the computer.
2. Immediately after the startup sound, press and hold the key
combination Command-Option-O-F.
Note: The Command key has the Apple icon on it.
3. Release the keys when you see a white screen that says "Welcome to
Open Firmware."
4. At the prompt, type: eject cd
5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the
action is complete.
6. Type: mac-boot
7. Press Return.
Dec 30, 2010 | Apple iBook G4 Mac Notebook
The container that hold my dvd disk wont come out when I press the open button on my apple computer?
It may be stuck so what you can try are one of these options:
Option# 1
* Shutdown your iMac G4
* Before you turn on your iMac, hold down your mouse button(s).
* Turn your iMac on still holding the mouse button(s) down.
* You will need to keep holding, until your disc ejects as your iMac starts up. That should do it.
Option# 2
If it does not, try using the Terminal utility to attempt to eject the disc.
* Click anywhere on the blank space of your desktop
and then you should see Finder appear near the Apple menu icon located in the upper left corner of your screen.
* Now from the Finder menu, select Go > Utilities.
* Within the Utilities folder. locate the Terminal application and launch it.
* When the screen prompt appears, type:
drutil tray eject
Option# 3
If that does not work, you can also try ejecting the cd using Open Firmware:
* Restart your Mac and hold these keys:
* Hold Command, Option, O and F keys while booting up.
* Now type: eject cd
To exit the open firmware screen type: mac-boot
One of these 3 methods should eject your disc.
If not, you may have a genuinely stuck CD in your drive and may need to take your iMac in to your local Apple retail store Genius bar or local Apple-authorized service center to have it safely and correctly removed.
Honestly, however, I have this same type of iMacG4- you will probably have the cd out by Option # 2 :)
Regards,
-Mactechtrainer
Jan 04, 2010 | Apple iMac G4 Desktop
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
APPLE MACBOOK WOULD BOOT. THE BOOT CD IS
unfortunately on the newer mac computer including the macbook you cannot boot to open firmware but there are other options
option 1)simply try holding down the mouse button or track pad button during boot after the first chime is sounded this will instruct the computer to eject the cd through the firmware
option 2) you can bypass the cd boot by holding down the option key after the first boot chime another simple solution this will allow you to choose a startup disk during...startup after which you can try the eject button on the keyboard or select the disk in finder and eject via trash can or eject symbol(symbol located in the open folder view of finder)
option 3) there is also a manual eject button though it may be harder to locate as they have change placements of it over the years however it can usually be found by probing the top center or far right of the cd slot with a paper clip just be gentle you don't want to damage an expensive piece of equipment by just carelessly jamming metal in it
you may want to try searching apple with your particular model and search for manual cd eject
best wishes, Crash
Apr 24, 2009 | Apple MacBook Mac Notebook
CD won't eject. I've restarted and tried all the fixes recommended by MAC forums and so far no luck. Any other ideas?
If it is just the computer that isn't ejecting the disk (and not a physically "stuck" DVD) there is a way to force eject.
Go to Apple menu > Restart and hold down your mouse button until the disk ejects.
Or you can try the firmware method...
If all other methods fail, you can try to eject the disk using the firmware (this may not work on all computers). To use this method, start up and briefly use the computer with only the firmware loaded, not the standard Mac OS X interface.
To eject a disc using firmware:
When you hear the startup sound, press and hold the Command-Option-O-F keys. (The Command key has an Apple on it.)
Release the keys when you see a white welcome screen.
eject cd
Press Return, then wait a few seconds. The disc drive should eject the disc, and "ok" appears on the screen when the action is complete.
Type:
mac-boot
Press Return.
Your computer starts up normally and you see the familiar Mac OS X desktop.
Apr 16, 2009 | Computers & Internet
Mini cd stuck in my macbook
You can try this:
  1. Restart your Mac.
  2. After you hear the startup chime, press and hold your trackpad button.
  3. After a minute or so, and you think nothing is gonna happen, the disc ejects.
  4. Release the button once the disc ejects.
Mar 20, 2009 | Apple MacBook Pro Notebook
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
See all Apple Customized 15" MacBook Pro Laptop Computer Questions
Computers & Internet Logo
138 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
