Question about HP LaserJet 4250n Printer
My printer used to automatically print from the bypass tray if there was paper in it. Now, it still prints from Tray 2 no matter what. How can I change the settings to take from the bypass when it's loaded so I don't have to keep pulling tray 2 open??
  • HP Master
  • 1,591 Answers
In the menu system of the printer you have to set the tray to "FIRST"
and you have to have a piece of paper loaded in the "bypass" (MANUAL) feed first BEFORE sending the print job.
Posted on Mar 23, 2011
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
    Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
    -Carl
    Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
    Toshiba 281C Bypass tray
    Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
    Feb 17, 2009 | Toshiba Estudio 200L Copier
    Tray 1- load plain letter
    Linda,
    On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
    Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
    Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
    light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
    If that dont cover it...post back
    Soulvisitor :-)
    Dec 18, 2007 | HP LaserJet 4100n Printer
    Can't print envelopes
    Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
    Solution
    thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
    Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
      1. Under the Tools tab, select Envelopes and Labels.
      2. Enter your Delivery and Return addresses.
      3. Click on Options
      4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
      5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
          • As Feed from, select Tray 5 (Bypass)
      6. Click <OK>
    Within the WorkCentre Pro 123/128 print driver
    After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
    • Under the Paper/Output tab
    Set the following features as follow:
      • Job Type: Normal Print
      • Paper Size: COM10
      • Output Size: Same as Paper Size
      • Image orientation: Portrait
      • Image Rotation: OFF
      • 2 sided Print: 1 sided Print
      • Stapling: None
      • Output destination: Center Output Tray
      • Offset Stacking: None
    • Under Tray/Layout
    • Set Paper Source to Tray 5 (Bypass)
    • Click on Bypass Tray Settings
      • Paper Type: Heavyweight (1 or 2)
      • Feed orientation: Portrait
    • Click <OK>
    • " on Specify Paper Type and select Heavyweight (1 or 2)
    • " (Apply> and <OK>
    • " <OK> again
    In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
    Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
    Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
    Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
    Can't print onto thick card
    Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
    Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
    HP LaserJet 4250n Printer Logo
    702 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
