Question about Motorola Mobility H700 Wireless Headset
I cannot get headset to stay on purple to pair it up with my phone, its fully charged and genuine headset but cant manage it.
    Sniper:
  • 91 Answers
When turning on your bluetooth device hold the power button down,for 8 to 10 seconds this usually puts the bluetooth inn pairing mode,then you have to enter a pin pairing code ,motorola and most other bluetooth manufactures use a 4 digit pin pairing code,motorola is as follows 0000,1234, and the others incase they dont work,are 9999,1111,try them in that order hope this helps
Posted on Mar 23, 2011
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
My h700 bluetooth will not go into pairing mode
hi sammieyoungj. i'm sorry to hear about your troubles with your headset. Maybe this will help your situation. Ensure the headset is fully charged. Then turn on the bluetooth feature (discoverable mode/set to look for bluetooth devices) on the phone you are planning to pair it with. Next, turn off the headset by closing the microphone boom. After about 8 to 10 seconds or you know the headset is off, press and hold the call button for about 4 to 5 seconds. The headset should activate and show a steady purplish colored light. When the light turns purple, unfold the microphone boom. If the lights stay a steady purple color, then the headset should be in pairing mode and you can revert to your phone to pair them together.
If the light does not stay steady, or turns a blue color, repeat the steps above, making sure no bluetooth devices are around that it may have paired with previously. Hope that helps. Best of luck.
Mar 05, 2011 | Motorola Mobility H700 Wireless Headset
Using h700 as a PC headset
Rjcroller wrote and is working fine. please follow....
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jul 16, 2008 | Motorola Mobility H700 Wireless Headset
Pairing
With the microphone closed, push in the call button. It should turn purple within a second or two. When it does release it and as quick as possible flip open the microphone. The light should stay purple and it is now in "pairing mode"
Jul 10, 2008 | Motorola Mobility H700 Wireless Headset
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700c
Hold the mutifunction button with the mouth piece close, until it turn purple, then open the mouth piece so that it will stay in the pairing mode. Now go ahead and have your phone or blackberry search for H700c
Good luck
Dec 13, 2007 | Motorola Mobility Bluetooth...
H700 Headset
Is the Samsung bluetooth turned on?
Jul 17, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
256 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
