Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
How can I connect my Desktop computer to my Hitachi 57F500 TV? I have an emachines desktop, running MS Win 7 connected from Monitor VGA port to DVI port on TV via Dynex DVI-VGA cable, but not getting any feed.
    Top Expert:
  • Hitachi Master
  • 74,871 Answers
Hello
VGA and DVI are not compactable. Your TV has no provision to connect it to computer.
DVI-HDTV Input (Input 1)
Use this DVI-HDTV Input for your external devices with DVI-HDTV output such as a Set-Top-Box, high-band DTV decoders, DVD
players and D-VHS with Digital Content Protection
1. Only DTV format such as 1080i, 720p, 480i and 480p are available for DVI-HDTV input.
2. The DVI-HDTV input is NOT compatible when used with a DVD player from a personal computer.
3. When connecting a Set-Top-Box with a copy-protect digital out terminal, a high definition picture can be displayed
on the screen in its digital form
OK.
Posted on Mar 23, 2011
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Can i get an adapter for my emachine monitor to go into a dell desktop ...my lead i have now doesnt fit as unable to screw it in
YES.
I believe it is time now for the guessing game............
1) Is the monitor about so high, and so wide?
2) Does the monitor look like a small TV, or is it flat in appearance?
3) What does the monitor cable look like?
4) Is your hair Brown, and do you smoke cigarettes?
NO.............just wanted to see if you were following along! Geez!
An Analog monitor, such as a CRT type of monitor, uses a VGA cable,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for a VGA Cable example.
Flat LCD screen monitors are Digital.
Some may have a VGA Cable attached, but the best cable option is a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(Click on any photo on those two Wikipedia pages, to enlarge)
Using these two examples, does one apply to the eMachines, and one apply to the monitor?
Let us say the monitor has a DVI cable.
The eMachines Desktop PC has a VGA port. (Connector)
For this you would simply use a DVI to VGA adapter,
http://www.directron.com/dviadapter.html
Now notice...........this is a VGA MALE to DVI FEMALE.
The DVI cable on the flat LCD screen monitor, has a male connector.
The contact pins of it go into socket holes, in the DVI end, of the DVI to VGA adapter.
The VGA port on the eMachines, has socket holes.
The male VGA connector end on the DVI to VGA adapter, has contact pins.
Point?
Make sure you get the correct DVI to VGA adapter.
There is a male DVI to female VGA adapter, also.
This is just one example.
For instance I'm using an HP 2009M 20-inch widescreen monitor, AND an RCA 26-inch HDTV, as dual monitors.
Presently using the HP 2009M with a DVI cable, and the RCA L26HD31 HDTV with a VGA cable.
(I'm also using an ATI Radeon HD5450 graphics card. Pretty 'pud', but it does OK for what I want)
Primer;
A computer sends out a digital signal. To get the best graphics quality, you ideally use a monitor with a digital cable. (DVI, etc)
When you use an Analog monitor on a computer, the computer has to change the digital signal down to an Analog one.
Therefore the graphics quality is not as great.
Digital cable technology now, is DVI, HDMI, Display Port, and Mini-Display Port. And some others I'm sure I've forgotten.
http://www.hardwaresecrets.com/article/Video-Connectors-Tutorial/157
For additional questions please post in a Comment.
Also post what the monitor manufacturer name, and model number is. (Look on the back)
Are you using the VGA connector on the motherboard, (Back of computer), or do you have a graphics card installed?
If you have a graphics card installed, what is the manufacturer name, and model number?
Regards,
joecoolvette
Mar 06, 2013 | Dell Dimension 4300 PC Desktop
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
I just want to know what kind of cable I need to connect my LTV-37w2HD TV to my computer?@highes.net
The video cable should be a VGA cable, assuming your computer has a VGA connector. Get one that has M/M ends. This is sometimes listed as a 15 pin D-sub connection. Then connect a 3.5 mm audio patch cord (m/m) between the audio out (speaker/headphone) pf the computer to the TV's VGA audio in (if you want to use the TV speakers).
If your computer has an HDMI or DVI output, I do not believe that you can connect to the TVs HDMI port. (The signal from the computer is not the same as that from a set top box.) If you have a DVI port, get a DVI to VGA adapter and then connect to the VGA cable. (You could use a DVI-DVI cable and then the DVI to VGA adapter at the TV. However, space is an issue at the TV.)
Make sure that the VGA port is enabled on the computer. (Some newer computers have a different video port enabled initially.) This may require entering your BIOS just after turning on the computer. Usually you need to strike Esc, F1 or F2 repeatedly starting when you press the power button. (F10 is also a BIOS access with some manufacturers - the key will be listed in a splash screen that is only visible for a few seconds.)
With the computer and the TV off, connect the cables. Then turn on the TV and set the input to VGA. Next turn on the computer. (If this is the only monitor attached, the computer should find the correct resolution (Windows). If you are using a dual monitor option, then you may have to enable the TV as a monitor. This will depend on the OS. For my Windows 7 laptop, it's right click on the desktop and choose Graphics Properties. Set the monitor options for both, external or attached and click Apply. Then click OK when a confirmation window appears. With my Windows 7 desktop, it's right click on the desktop and choose Screen Resolution. Similarly choose the settings, click Apply then OK to confirm.)
I hope this helps.
Jun 02, 2011 | Westinghouse LTV-37w2 HDTV
I want to connect a HP w2207 monitor to a HP TouchSmart IQ770 PC. What is the best way to do this?
Your HP w2207 monitor has support for both VGA and DVI inputs. This therefore means that you can connect your HP TouchSmart IQ770 PC via either of these two connectors.
VGA is the blue coloured port on the rear of your monitor.
DVI is the white coloured rectangular port located on the rear of your monitor.
DVI is the better connection of the two as it is a digital connection, so use this one if you can, alternatively you can use the blue coloured VGA cable to connect your monitor to your computer.
It all depends on which output, either DVI or VGA is found on your Computer. Remember VGA is the Blue coloured port and DVI is the blue coloured port.
All the best!
damnor01
Feb 01, 2011 | HP TouchSmart IQ770 PC Desktop
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
Can't connect my emachine to 50" samsung plasmatv mod#pn50B530S2F
try going to "display properties" and adjusting the settings there. Right click on the desktop wallpaper and go to properties, then click on the settings tab. Make sure the TV setting is turned on
Mar 28, 2010 | Acer Aspire L100 PC Desktop
How to connect Samsung 40" LCD tothe eMachine desktop T2615. It looks like there is only one connection for a monitor? The computer is about 6 years old.
Older LCD TV's have a variety of inputs, one of them being VGA, to connect to your PC. The problem seems to be that you either connect your PC to its own monitor, OR to the TV, but not both? If that's the case, you may have a couple of alternatives:
The most expedient one would be to get a VGA splitter cable; the other, more expensive: replace your video card with one that has dual outputs: either one with two DVI ports; one with one DVI port and one VGA port; or one with one DVI port and one HDMI port. As you can tell, there are several possibilities, depending on the connectors available on your TV.
Sep 08, 2009 | E-Machines eMachines Desktop PC
WANT TO HOOK MY COMPUTER TO MY TV? COMPUTER : T6534 EMACHINE TV SET : MAGNAVOX WHAT ITEMS DO I NEED?
You Need a VGA to DVI Connector and a dvi cable which connect at the back of the tv.
you need to connect the VGA Port(Blue Colour) with VGA to DVI connector and then Connect DVI cable and Connect your computer.
Jul 14, 2008 | Computers & Internet
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
583 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
