Question about Toto MS950CG01 Cotton Neorest One-Piece Tankless Tankless Toilet MS950CG
We are an info Center for a community. The pool company came out yesterday & cleaned the pool using most of the water pressure. since they left the toilet will not flush. is there an easy fix to this issue? The sink seems to be fine.
  • 8,404 Answers
Believe it when I say the pool is not connected to the toilet.
You are not clear as to what actually happened, I presume the pool company came in and attached a hi-pressure cleaning device to your water supply. As such, they were definitely using your fresh water supply which should not have made much difference on the pressure. You say it did, ok. When the pressure went down in your water line, there is that possibility that the toilet would not fill as fast as when full pressure is available but that should only be a matter of minutes not hours, particularly if your toilet is a tank type.
You say you are in a community center, I must presume you have at least a one inch water line into your building and probably much larger, you may have a tankless toilet with a meter valve ("Sloan") on it - meaning you have enough water in your water system to support a direct flush and do not require a tank.
It could be that scale inside your pipes was disturbed by the high flow of water and the scale found its way to your "Sloan" valve, blocking the flow of water. To check this, turn off the water supply to the toilet, remove the top of the valve and clean it. Reassemble and turn the water back on.
I hope this works for you ... thanks for your quesiton @ FixYa.com
Posted on Sep 19, 2011
What is the purpose of building a community hall?
To avoid confusion & anarchy.
Power corrupts...
Absolute power corrupts absolutely.
(Again... still... without fail).
We the People come together out of need
(a long history: works best in fresh air & full daylight).
Community Halls should only be built when EVERYBODY has their own building ... and there's NOTHING BETTER to accomplish.
It is a wonderful place for people to come together and get out of the clean clear.... purifying sun-light.
Once you are able to CONTAIN people into a shaded confined area... they can be observed and properly controlled. Dissent can be properly stifled (for the common good (besides it's just negative... usually pretty painful to hear)).
If people are allowed to run about unsupervised... they begin to manifest notions of ownership, self worth, freedom & determination.
If these notions are left un-checked then who will wash & clean for the power elite... pave their roads, produce their energy, food, clean water, build their lavish houses, pump out their filth & carry their recycling...
No no no... you must have a pretty enclosure... A forum where the MANY ... can be "heard" (and watched closely) by the few noble elite...
who would GRACIOUSLY sacrifice themselves to lead us all to a municipal success... where we can be PROPERLY TRAINED, controlled & taxed... & taxed... and taxed...
To pay for that bigger... better AGENCY to preserve
our "freedom"... liberty & justice...and HUGE PROFITS...
for our AUGUST POWER ELITE...
(GREED is good?) ... ((Only if you are in charge)))...!!
Else... we would not all be LIKE MINDED...
We must enforce that "community"... not out of need...
always about POWER & GREED.
(I'm just saying).
Typically...
the purpose of building a COMMUNITY HALL...
Is to make sure somebody's buddy gets rich in the process.
19.5 TRILLION DOLLAR National Debt threshold...
got passed yesterday... and we "people" are passing
more debt daily... Heck... Build TWO COMMUNITY Halls...
you can pay it off for the price of a loaf of bread tomorrow.
http://www.usdebtclock.org/
Sep 02, 2016 | Miscellaneous
When i clean the filter i notice that there is water left in the filter hole .is that okey
How much water should I expect to be left in a dishwasher ...
diy.stackexchange.com/.../how-much-water-should-i-expect-to-be-left-in...
May 15, 2011 - After every load there is always some water left in the bottom of the drain basket/filter. It's not up into the dishwasher itself, but when I reach into the filterto clean it, there's always water in it. ... I did notice some string and guck wrapped around my food chopper blade .... Making holes in 3D objects (Unity).
Cleaning a DE Filter - Troubleshooters.Com
www.troubleshooters.com/pool/de_filter_cleaning.htm
Make sure the hose has no large holes, and that it's tightly secured to the waste ...Water is pumped into the filter housing at high pressure, it passes through the DE ... He has cleaned the center, but the left and right sides have not yet been .... Is there a pool store open that will help you reassemble, assuming you drive all ...
Dec 29, 2015 | Dishwashers
Sta Rite Pool Pump
Probably need new pump if the impeller broke.
If impeller broke, then motor will run, but no water circulates
Call pool company.
Motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 18, 2013 | Sta Rite Pool & Spa
I sent an earlier description. Shelved unit for 6 months - dropped in water yesterday and it ran all day. Cleaned liner - put back in water and it ran for 45 seconds and stopped - same as before - What...
The control board inside the motor pack is likely failing. Let it sit long enough and it resets. The only 'solution' other than your current 'use and wait to use again' method is to replace the motor pack to the tune of ~$450 parts, labor and shipping assuming there is not a service center within driving distance.
For info on where you can get it serviced you can contact the manufacturer directly at www.maytronicsus.com or 1-888-DOLPHIN.
John
Arrow Motor & Pump
Aug 27, 2011 | Dolphin Maytronics Advantage
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started...
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Jul 15, 2010 | Hayward Pool Products Hayward Xstream...
I have a Pentair whisperflow pump/motor and I keep losing water from my pool when the system comes on. It seems to like **** a bunch of water out. I had pool company to come service and clean system, but...
If you don't see any leaks check your Backwash. If it has any water coming out of it you have a problem with the valve. Hope this helps but I can't say more without inspecting the system. You may need another pool service look for the problem but check the B/W first.
Feb 22, 2010 | Pentair 1hp Whisperflo Pool Pump In -...
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Toto MS950CG01 Cotton Neorest One-Piece Tankless Tankless Toilet MS950CG Logo
51 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
