Question about AudioBahn A435HCQ Car Audio Amplifier
Fuse is broken at the moments power up - AudioBahn A435HCQ Car Audio Amplifier
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AudioBahn Master
  • 2,226 Answers
You probably have blown output transistors.
Posted on Mar 23, 2011
The 10amp fuse keep blownin the 10amp fuse goes too acm
Sorry, at the moment I don't understand acm? Is the fuse in underhood fuse block or interior?
I did look at power distribution fuse wiring for your vehicle, didn't see acm?
Apr 29, 2016 | 2001 Saturn SC
Why is my Vizio E370VLE 37 in LCD HDTV recieving no power when plugges in?
Check to see if there's power to the outlet the set is plugged into.
Dec 01, 2014 | Vizio Televison & Video
110V fan has been plugged in 220V power socket
You may be lucky enough that the capacitor exploded from the 220 volt charge. You will have to enquire at an appliance repair shop for exact advice. Basically I would junk it and get the correct unit for the voltage and cycles in you area.
May 17, 2013 | Dyson AM02 Tower Fan
LD-4655VX
Set has a conventional fuse--follow the power cord inside as it goes directly to the fuse--if power light comes on at all even for a moment the fuse is good and you may have a power supply board bad.
also look for puffed up caps on the power board that look like these=
Apr 15, 2012 | Westinghouse Electric LD4655VX TV
My phone on/of button is broken is there a way to boot it up regards
There is no other way to boot up your phone except your power switch. In emergency usage, if your power switch / button is broken you've better remove the button then use small - screw driver to connect the power lead / wires for a moment to get your cell phone On. Again this just for emergency.
Regards
Apr 19, 2011 | Nokia 5310 Cellular Phone
2001 for tarous code p1633 what does that mean
P1633 means KAM (keep alive memory) power is low. The power that goes to the vehicles computer to hold its memory when the key is off has lost its power. I would start by checking fuses in the fuse panel in the engine compartment(near the radiator support). If the fuses are all good then I would test for power at the computer connector which is also in the engine compartment behind the engine. I don't have the pin number or wire color at the moment (I apologize) since the Ford website is down at the moment. I have repaired this problem in the past by installing another power wire to feed the circuit essentially bypassing the original circuit.
Hope this helps
Apr 04, 2010 | 2001 Ford Taurus
2005 golf radio does not power up
replace the fuse if its broken or u might need to check the fuse of the radio itself if it has one. if it still not working then u might need a radio replacement
Jul 02, 2009 | 2005 Volkswagen Jetta
I hooked up the battery reversed for a moment now Amigo dead
fusible link to starter from positive battery post is smoked. It will be a thick part on your cable.
May 16, 2009 | 1989 Isuzu Amigo
Samson Resolv 65a Speaker - No Power!
There's a fuse input just underneith the mains input plug.A small screwdriver will open the small latch.You can get new fuses at Maplins.
Jan 07, 2008 | Samson Resolv 65a Main / Stereo Speaker
AudioBahn A435HCQ Car Audio Amplifier Logo
22 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
