Question about Weller Welding Tools
Hi, I have a Weller PS-2D station with a TCP iron and the iron is not heating up. I've tried the iron on another similar unit andn it still doesn't work. I've checked the connections at the connector end and also stripped down the iron itself to check the connections and they seem fine. Another iron used in the same station works ok so it must be a faulty iron. Is it possible to repair the iron and what is the most likely problem - the heater or something else?
4 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: I have a faulty weller soldering iron.
It may be possible that the voltage
input is low it will affect the
temperature.if not change the
thermostat
Posted on Apr 11, 2010
  • 33 Answers
SOURCE: I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Posted on Aug 30, 2010
SOURCE: I bought an old Weller solder iron station at a
The TC201Z is a zero crossing switch version of the TC201T. The two handles use the same tips which are the Weller PT series.
Posted on Sep 10, 2011
Weller WES51 does not heat up unless I turn to 700 degrees or higher
You may have a broken wire in the temp sensor in the tip of the iron or near where the iron connects to the base.
Jan 24, 2014 | Weller WES51 SOLDERING STATION
Solder tip is worn out need to replace, how do I remove the old one weller model W-TCP
The barrel to the soldering iron has a nut on it and the nut unscrews and the whole barrel comes off. The tip then comes out of the barrel.
Jan 13, 2013 | Cooper Industries Weller Field Soldering...
Weller WD1. At power on screen says "OFF". The 3 preset temperatures are still displayed. Tested with a working lead and soldering tip, OK.
Just press UP/DOWN at the same time quickly. If you hold them down you will get to the menu but just pressing them and releasing them will turn the station back on.
May 31, 2011 | Weller TC201T: Soldering Iron For Wtcpt,...
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just...
its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Feb 25, 2011 | Weller Welding Tools
Unit does not heat up to temp and green light blinks
hi, i have faced the same problem with my station also. the issue will be only with your 6 pin connector, check whether all the pins are getting connected properly. some times when u apply force the connector's pin may go inside. check up with that.
Nov 04, 2010 | Weller WES51 SOLDERING STATION
Jul 11, 2010 | Weller Welding Tools
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Welding Tools Logo
237 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
