Question about Car Audio & Video
Question regarding my speakers, i have a 2400 mono block power acoustik amp hooked up to 2 12" kicker l5 with a 0 gauge wiring kit and a capacitor. everytime i turn up the volume the speakers gets all crazy and wont stop beating. and every once in a while the speaker starts beating out of control for no reason. is there something wrong with my amp? or like my connections?
    Sniper:
  • 50 Answers
Hello... sorry to hear you are having problems. Though there is no actual way to diagnose a problem 100% without seeing it in person and checking everything... it sounds to me like one of 2 problems. First, make sure you have a good ground connection. Do not use factory body bolts, seat bolts, trunk lid bolts, etc. Put a ring terminal on the ground wire and connect it solidly with self-tapping screws directly to a CLEAN unpainted bare metal part of the car. Use a wire brush to throroughly clean the grounding point. You also need the same size grounding cable at the battery between the negative post of the battery and the body of the vehicle (body ground). If you require a 0ga connection for ground and you connect to the body, but you only have an 8ga body ground at the battery, that will not suffice. The second thing I would check would be the RCA cables. It sounds like you may have screwed through the RCA cable or pinched them. These are to good candidates for the problem you are describing. Hope this helped. If you need further assistance, just add a comment and I will reply back. Good luck with your venture!
20 year car audio/video installer
Bay manager
Posted on Mar 23, 2011
I have two kicker cvr dual voice coil 4 ohms to a
what about the remote power wire from the radio? 2 channel or four channel(amps)? are the speakers running parallel or in series? are you using a mono block? or an EQ?
Oct 13, 2014 | Car Audio & Video
How do I wire a kicker mono amp for my subwoofer to a kicker 4 channel amp that is already hooked up to run the 4 6x8 speakers
you should have an output on the amp running the 4 6/8's connect to kicker inputs hope you got a cap(capacitor)to run this set up and a good wiring kit.if so just run all the power cables to the power block feed the amps,ground them and don't forget the remote wire and you should be fine
Sep 23, 2014 | Car Audio & Video
Is it safe 2 install these subs 2 a 2000 watt power acustic amp and if so how do I wire them for a 1 ohm stable load
It looks like you have the Power Acoustik OVN1-2000D Mono Block 2000 Watt amp.
Monoblocks all feed speakers normally and cannot be bridged. So hookup your speakers
as normally with + on the amp to + on the speaker and same with the -.
Now for the speakers. I dont know too many Kicker speakers that are 1 ohm but the
monoblock wont care. It will feed the 8,4,2 or 1 ohm speakers the same power. You just may
get less response from the higher ohm speakers-less Bump Bump. You could wire your speakers
in series to get a lower ohm load (2-4ohm speakers in series gives the amp a 2 ohm load) and get
better response. Here is a site that answers many electrical and speaker questions.
See # 57 on the right hand pane. Tells you exactly what will do best. Good luck.
Electronics Answers Made Easy
Apr 27, 2011 | Kicker Car Audio & Video
Car subwoofer just past half volume cuts off the amp
Assuming there is no short, or lose ground wire somewhere inside the box, diodes( in the amp) are fine, you might be overheating it by not allowing it to get good ventilation. This can be a big deal on some low end Chinese amps. Or the speakers are blown , or your Resistors (in the amp) are bad, but for arguments sake.
Most people don't use the proper size and or conductivity types of wiring, for pushing high amperage Think about it like this, Watts (power) =.Amps (energy) x Voltage (pressure) Resistance or Ohm's (amount) determines how much Wattage will go in or out, Ohms = Volts x2 / Watts.
What gauge wire are you using on your setup?
Jan 09, 2010 | Car Audio & Video
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Aug 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
HOOKING UP 2 AMPS
Ideally you would use 1/0 gauge power and ground wire for the amps, and use power distribution blocks to reduce it to 4-gauge for each amp. Any smaller wire would be less than ideal for that much amp power.
If you're buying a power wire kit, it most likely won't have a separate distribution block for the ground wire (usually they have separate ground wire for each amp or one piece that's long enough to cut and have wire for both). This is fine, but you should look for a kit with at least 3 feet of ground wire per amp - any shorter and it's a struggle to mount the amp close enough to a ground point. As above, the main power wire to the battery should be 1/0 gauge.
Lastly if a 1/0 gauge kit is not available, 2 separate 4 gauge kits will work, however that's obviously a lot more wire to run and conceal.
Feb 21, 2008 | Car Audio & Video
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
