Question about Kenmore Washing Machines
Have a 700 series kenmore washer, model #27721600, serial #CT3220533 purchased 8/16/06. Machine still works beautifully except it is leaving round rust spots on my clothes. The rust seems to come from the bottom row on the sides of the washer. Porcelon tub so shouldn't have rust coming out. Just started 2 months ago. Why would I get rust stains?
SOURCE: Wasing machine leaves rust spots on clothes.
My kenmore washer basket has noticable chips on the inside and has rust stains as well, it is only 5 years old. how can I find out about the 10 year warranty?
Posted on Jan 13, 2008
  • 73 Answers
SOURCE: kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
Posted on Feb 07, 2008
  • 1073 Answers
SOURCE: Kenmore 700 series washing machine
check to see on the top of the basket if there is a balance ring it will look like a large doughnut if it has one and if it is loose or if the fluid in the ring has leaked out then this will cause the out of balance while in spin let me know if i can help 276 523 4434
Posted on Apr 25, 2008
SOURCE: kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
Posted on May 11, 2009
Hold old is my Kenmore 700 series washer
go to the Kenmore manufacturer web site. find the Washers product link or go to their customer service and enter the serial number to get any details they might have about the model.
Feb 03, 2018 | Kenmore Computers & Internet
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Kenmore washer
most likely you have a sock or, some cloth obstructing the pump.
you will have to bail out the water then: remove the Sears 700 series 4screws holding the washer's control panel and, remove the washer side clips under the panel to remove the washer's sides then remove the 8 pump screws to remove the pump face and, remove the obstruction. the
exploded drawings can be found at: http://beta.searspartsdirect.com/partsdirect/index.action
Jul 14, 2010 | Kenmore Washing Machines
Need age of my washer machine
Kenmore elite model number 22054100 serial number CL210158. How old is this washer?
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Series 80 Washer leaking oil underneath
TRY TO CHECK THE RUNNING CAPACITOR MAY BE THE OIL THAT YOU SAW CAME FROM THE DAMAGE CAPACTIOR.
Aug 21, 2009 | Kenmore 22642 Top Load Washer
I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Jul 07, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Dryer - Series 80 - Model 96586200
the brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Oct 12, 2008 | Dryers
Washing Machines Logo
144 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
