Question about Miele S548 Bagged Canister Vacuum
My 2001 miele stopped working Black cannister. I believe cleaning ladies overheated it as the bag was very full and the vac felt warm to touch. I replaced bag and let cool down but it will not start. This has happened before and the vac store said they replaced the cord because it tends to go when it over heats. I have not taken in for and estimate but I fugure it will be at least $150 to repair. Is the another option.
  • 71 Answers
SOURCE: poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
Posted on May 02, 2009
  • 112 Answers
SOURCE: My almost new miele Dog and Cat vac keeps telling
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Posted on Aug 12, 2009
renevacdoc
  • 84 Answers
SOURCE: I have a kenmore cannister vac - model 27514. Do I
You know, any bag made for the unit should give similar results. You can buy a cheaper bag and that number is 50558. You can get them at your local vac shop or you can let me know, I will send you some. The price per 3 pack is only 4.95. The canister vac is made in such a way that it doesn't have much leakage. It is quite efficient with or without hepa bag. If you or anyone in your family suffer from asthma, I would recommend the use of the hepa bags. tThanks, Rene(The Vacuum Doctor)
Posted on Nov 10, 2009
  • 16 Answers
SOURCE: Opened the cannister to remove the bag. The tube
Steve,
This may be, and I stress MAYBE an issue with lining up the snap on the collar at the end of the hose (black tube). Please look carefully, using a flashlight or other bright light if necessary, to see if there is any indication on the collar for lining it up to 'snap' together. Unless the locking mechanism is broken off this should solve the problem.
Posted on Dec 04, 2009
VacuumRepair
  • 438 Answers
SOURCE: replace the power cord on a miele s514 cannister
Greetings from GoVacuum,
Ok, so you need to replace the cord reel on a Miele S514 Solaris, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel (hopefully from GoVacuum), You may purchase the S500 Series Cord Reel Here; Miele Cord Reel - s500 Series #5240304 .
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to send me an email chris.jones (at) govacuum.com if you have any questions about the repair that I can help you with, I'm always more then happy to help. We stock all the supplies you need for your Miele S514 Solaris including the FJM Bags, the Super Air Clean Filters, HEPA Filter, and other Attachments & Accessories.
If this repair guide was helpful to you, please click the four thumbs up icons in the top right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Posted on Mar 18, 2010
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Stopped working while vacuuming...less than 2 years old???
Hi, It's probably the cord. I do wish Mieles were more durable given what they cost. I clean a home 3x per week with a Miele and tend to go further than i should before i unplug and find a closer outlet to plug into. So, it's the tugging on the cord that killed it. I had to take it to a Miele certified repair shop and they replaced the cord itself, which of course had a new plug on it. It was around 60 bucks. The owner didn't speak great English and I don't know Spanish so i'm unsure where the prob was: the spot where the cord attached to the vac, or the plug. In any case, I don't tug on the vac anymore....owner's were unhappy. Lesson learned.
May 14, 2010 | Miele S251i Plus Bagged Canister Vacuum
Steve,
Dec 04, 2009 | Miele Cat & Dog 326i Bagged Canister...
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Accessing motor Miele Flamenco II
I had the same thing happen to my S251. Open up the vac. There is a third hidden screw in the groove where the accessory door is hinged. It's really well hidden, use a flashlight. Once its open, you'll have access to the power cord and you can test its conductivity. I didn't really believe it could be something as pedestrian as that, but the retractable power cord takes a lot of abuse, and eventually it fails. Replaced mine and the vac works great.
Jul 31, 2008 | Miele S251 Flamenco II Bagged Canister...
Overheated vacuum
It normally won't over heat unless the bag is too full, the filters are clogged, or you have have a clog in the hose or down by the brush roll, the inlet may be clogged. Some will restart after a while, some others have a reset to push. If it won't power on, then you have a problem and it will have to serviced.
Mar 20, 2008 | Simplicity 7850 Premier Bagged Canister...
Stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
Miele S548 Bagged Canister Vacuum Logo
56 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
