Question about Epson Stylus CX9400 Photo Printer
For sending multi-page fax, I get the feed error after scanning the first page in Epson cx9400fax. please help.
  • 41 Answers
That could be many things. Check your feed rails are tight against the paper. Also make sure you are not
overloading the feed. For other suggestions go here -
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1635278753.1300892813@@@@&BV_EngineID=ccgcadfddljflficfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=90753&prodoid=63070382&foid=102327&cat=30961&subcat=30959
Posted on Mar 23, 2011
What is error message 0407?
EPSON Stylus error message 0407
Aug 11, 2014 | EPSON Stylus CX9400Fax Series
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
May 16, 2010 | Brother MFC 490cw Color Inkjet...
Fax Problems
check and verify that the land line is correctly plugged into the right connector at the back of the fax.. secondly check that you actually have a dial tone.. this is not a fax problem.. its a connectivity problem.. Smiles
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | Epson Stylus CX9400Fax InkJet Photo...
I have an Epson CX9400Fax all in one printer, fax, scanner. Yesterday it quit accepting print commands from the computer. It still copies, scans and saves scan files from the unit to the computer so I am...
Reinstalling the software is great, but did you first remove your printer usb cable, uninstall the printer and then re-install your software?
If not, do those 3 steps in that order and try printing again.
Best wishes,
Graemevm
Dec 17, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
I have a problem with finding the full software/epson CX9400fax
Please send the model numberof your epson printer. that is the only way you can be helped. There are so many epsons with the same capability as yours.
Cheers!
Apr 15, 2009 | Epson Stylus Multifunction Printer/...
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Epson multi fuction printer will not pull the paper in when faxin
Red Light remains on, it make a noise. but nothing happens
Feb 16, 2009 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
161 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
