Question about Orvis Rainbow 191Y0000
Orvis Rainbow Watch Where can I get a Battery replaced and atwhat cost
Frenzy watch #FRZK1103 light up function no longer works, even after replacing battery. Is there a simple fix?
No simple fix, you will need a watch repair shop to fix this, but make sure you get a repair estimate, it may shock you.
Dec 07, 2014 | ACCUTIME WATCH CORP. Frenzy Ladies Watch...
How to set pocket watch
Hi John, There are several possiblitites depending on the watch you have. If it is a battery watch you set it like most modern watches by pulling the pendant and the hands should move. If it is a vintage watch it may set the same way. If gentle pulling the crown does not work try this. Your watch may be a lever set watch. This requires removing the crystal of your watch will be screwed on. If it doesn't loosen easily try putting the watch between your palms and twist. Once the crystal and bezel loosen remove it and set it aside. Now look near the 2 o'clock position. A lever set watch will have a small metal piece sticking up that is designed to be hooked with your fingernail and pulled out. When in the out position your watch will now be in the setting position and your hands will move when you rotate the crown. After setting push the lever back in and you will now be in the winding position. Replace the crystal and carefully screw it down but not too tightly. There are other systems but I am guessing this will cover your watch. Merry Christmas
Dec 18, 2011 | Orvis 82KG6000
How long should a bulova watch work ---my husband bought me a bulova watch 7 years ago ----it stopped working & I thought I just needed to replace the battery ----so I did but less than 3wks later the...
I would expect the battery to last more like 3 years than three weeks.
Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery?
I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced.
Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
Oct 14, 2017 | Bulova Diamond Watches
My strap is broken and out of warranty. How much could I expect to pay for a new strap and battery for this watch?
A replacement watch band may cost as little as $10 and a replacement battery may cost as little as $2. However, if you do not have the right tools or do not feel comfortable performing this service by yourself, expect to pay $5-10 to have your battery changed by a professional. Band replacement may or may not be included in the band purchase price. Retail prices for most metal bands are higher than the price for lower-end leather bands, but premium leather bands may cost upwards of $20.
For the most reasonable price, try looking for a watch kiosk at your favorite shopping mall. Some Walmart jewelry counters will also provide this service. A full-service jewelery store should also be able to provide this service, though at a higher price.
May 06, 2011 | Diesel DZ4064 Watch for Men
IT IS AN ORVIS AUTOMATIC AND IT STARTS AND STOPS AND DOESN'T KEEP CORRECT TIME.
Thank you for contacting FixYa.
When you first receive your automatic watch, you must give the watch an initial pre-wind. If you wear it everyday, it will continue to wind itself on your wrist when you move around and walk. If you stop wearing it for more than approximately 2 days, the watch will need to be reset, but will then automatically wind itself once you start wearing it again. The disadvantage to this is pretty clear. Your watch does not t keep time if you do not wear it constantly. The advantages are that you will never have to replace a battery, the watch keeps great time when it is running, and most of all, this type of movement is exactly what the originals use! If your Automatic is losing or gaining time in a 24-hour period the watch needs to be adjusted. All of our automatics have an adjustment screw on the movement just like the originals. Any local jeweler can service these watches.
Best regards! Jewel
Aug 25, 2010 | Orvis Watches
How do I change battery.
mcdevito75 here, You:d need a couple of watch tools to change the battery, the cost of these tools and the cost of a watch repair shop to change the battery for you are similar. Look for a small watch repair shop in your area to save on the cost of replaceing the battery.
Jun 17, 2010 | DKNY Leather #NY1328 Watch for Men
What type of battery do I need for a Rado watch (111.0322.3) - thank you.
Examine the markings on the battery. It is likely to be a 1.5-volt Silver Oxide or Alkaline battery. It doesn't matter which one you use, although the Silver Oxide battery can handle heavier energy-consuming loads, such as a multifunctional chronograph. It can be purchased from amazon, here: watch battery 1 5V silver oxide 357 SR44 SR44SW 10 pack. I hope this was helpful. Cheers
Simon
Nov 04, 2009 | Rado Integral R20383142 wristwatch
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
Field & Stream Mens Watch, F42GUBS
Take the watch to a jeweller. They should have all the batteries and seals and tools necessary for the job, and it rarely takes long or costs that much. you could probably manage yourself, but getting the seals especially is easiest through a jeweller anyway. Most likely reason for any watch to be not working is the battery, the next would be moisture inside - normally visible round the screen/face. always worth replacing the battery to see, unless the watch cost less than the battery, which it didn't. Hope this helps :)
Jan 25, 2007 | Field and Stream Magnum F42GUBS Wrist...
Orvis Rainbow 191Y0000 Logo
46 people viewed this question
Top Orvis Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Orvis Watch Expert? Answer questions, earn points and help others
