Question about GPS
I have a Galaxy DX99v, that has no audio. The Radio transmits and receives. When I plug in headphones into the external speaker output and set the volume knob to 100% I can hear soft static. I have verified the speaker and wiring are in working condition. Just out of Coincidence , I picked the radio up by the faceplate and the volume came up to ~25% and tinny. Squeezing the face plate was allowing the faceplate to touch the top pins of the mode function switch(several pins soldered together going to a yellow wire to the main PCB). I have probed around and have not discovered any shorts or loose wiring, etc.
SOURCE: Garmin 530 Radio problem
Did this start happening after the latest download? If so re load the current version of the software and do not turn off the radio until the download is complete.
aburkett61@comcast.net Please answer back and let me know.
Posted on Jan 21, 2008
  • 46 Answers
SOURCE: 75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Posted on Mar 15, 2008
shaggyrat
  • 1224 Answers
SOURCE: 2004 Harley UC Radio - no sound on Left side
how about the antenna this could be the main problem im not a motorcycle expert but radios i do know and if your getting static the antenna which is called the aireal << spell check is not picking up enough signal
also head phones could be also a bad set
Posted on Jun 10, 2008
  • 27 Answers
SOURCE: Cobra 148 gtl Low / No receive audio
No audio out / low audio out....This is a constant problem with the COBRA 148 gtl....to get a good level of volume replace the
electro caps ...start around the two speaker wires and work back from there. I'm in the process of rebuilding a 148 gtl and have found caps that are leaky and dried out...after replacing nine the volume went up to a good level...now i need to fix the distortion
and background hash. Did you know that there are many posts
on FIXYA about this same problem I.E. great TX , great PA but poor , or no audio out. these sets have been made in sevetal countries...The sets made in Taiwan or China have poor quality
front panel pots (the carbon track is micro thin and simply wares through to the material the track is printed on) This has the same effect as removing a wire from a pot I.E. no audio. The good news is that 99% of parts in the radio are freely available and that includes the front panel controls. ONE WONDERS IF THE SET IS WORTH THE EFFORT !!!
CHEERS GUYS / GIRLS.
Posted on Jul 03, 2008
micromaster
  • 3614 Answers
SOURCE: Suddenly have no audio from speaker or earphone jack
is display icon appear on the unit are all normal?
Posted on Aug 08, 2008
What do I have to do to hookup a headphone to my 60 in vizio TV?
Without opening set, easiest thing you can do is hook up a small receiver to the audio outputs of tv and then plug your headphones into the headphone output of receiver. And when not using the headphones you can always hook up some external speakers to the receiver - they will always sound better that the speakers that come with the tv.
Feb 23, 2017 | Vizio Televison & Video
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
No output to speekers Sony STR-DE825
Check that the mute is not on.If a headphone is plugged into the receiver the speakers will be muted.Verify the the output selector is set to the correct source.Here is a simple check.Select a strong FM radio station.Plug in a headphone.If you are receiving an audio thru the headset.Then disconnect the headset and see if the audio is transmitted to the speakers.If you still have no speaker sound check to see if the speakers have fuses which may be blown.I would try another set of speakers to determine if it's the amplifer or the speakers.The amplifer has fuses as well. Wiilbe inside if not at the rear
Oct 21, 2012 | Sony STR-DE825 Receiver
The antenna will not power up
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Remember that if the audio to the transmitting unit is quiet OR off for about one minute, the transmitting unit will turn off and you will hear FM noise, loudly, on your headphones. This is due to the "lack of audio" timer built-in to the transmitting unit.
May 16, 2010 | RCA WHP140 Consumer Headphones
Cannot get power to the unit the light indicating power is out
I have the same model as you. I have two transmitters and three headphones actually. Please see below:
Apr 24, 2010 | RCA WHP140 Consumer Headphones
Red light isn't indicating it detects source
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. (This being your IPod - Turn it full blast). Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones till green and adjust its volume as well).
Note: Some radio stations bleed over into the headphones and you may have gotten the "Beautiful Music" from this radio station frequency harmonic anomaly. Keep tuning your headphones till you hear your music or audio source.
Jul 26, 2009 | RCA WHP140 Consumer Headphones
Power goes off!
May 18, 2009 | RCA WHP140 Consumer Headphones
External jack
sounds like you got a good radio to practice on . If it was given to you then you have nothing to loose except what ever you put into it. try hooking the speaker jack back up, see what it does??
Apr 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx99v cb radio
did this problem occur while radio was being operated? or when it was being worked on? or a result of being worked on?
Dec 04, 2007 | Galaxy Radios DX- 88HL Base CB Radio
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
