Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Router my neighbours are using there computers from my router i would like to block them
    Problem Solver:
  • 11 Answers
You need to use some form of encryption for your network. WEP is the most basic, but WPA would be better. Consult the helpfile or router manual for specifics.
Posted on Aug 03, 2008
I m unable to connect wifi for my samsung 65 led tv
Does the TV have WiFi enabled? Is it in range of your WiFi router? Is the place where the TV is located a WiFi dead spot? Does the TV see your WiFi router, and is it the strongest signal in the TV's locality? Are your neighbours using the same WiFi channel as you? Have you got the router set to block MAC addresses? Is the TV set to use DHCP? Is the router handing out IP addresses? What security level are you using? Are you putting in the correct WiFi password? The list goes on and on.....
Sep 06, 2014 | Samsung Televison & Video
Virus Check
when my F761usa screen turned black just happened I was reading my emails, since then I never can turn on my F761usa, not even get bios reboot. I thought I got deadly virus attacking to kill my notebook. during investigation we found our neighbour invaded our wireless router (we can see Nikky ipod as device name appeared in router, we blocked it then another Nikky phone as device name appeared again), meanwhile we found log files recording naughtyamerica website, we realized our neighbour visited some dangerous websits that's why I kept getting very dirty-emails over past 3 years.
By adjust netgear and notebook parameters setting finally our neighbour can't steal our internet services any more.
Then we spent $10 to convert internal HD as external usb HD and could be accessed by our another HP DV7. I doubt it was virus caused it.
we has att DSL internet services which provides McAfee, we has very old Netgear WGT624 wireless router but can block/data secured and window vista provides network secured setup.
we didn't buy any other virus software but run the free version(advanced systemcare).
Sep 08, 2010 | HP Compaq Presario F730US Notebook
How to use the wireless key
Wireless keys are like your secret password. Provided you have a wireless router and wireless devices to access internet - You might want to secure the wireless signals emitted by the router to ensure that your neighbour is not using free internet :-). So all you do is access the router's setup page and under wireless tab enable the wireless security feature.
Wireles security generally of two types
- WEP
- WPA
select the one suits best to your network and save the changes. once you are done with the router - you will now search for wireless network from your computer/s and select the network. The router will now ask you to type the password (the one you eariler entered on the router). Enter the correct password and you will be connected. Now your neighbours can see your network but cannot access it unless you share your password with them.
May 10, 2010 | Computers & Internet
WRT150N router works at a close range but most rooms in my house I am unable to pick up a signal. Although I can see all my neighbours signals on my computer
Your neighbour has either a range max router, or his router is set on maximim range. You should be able to set you router to long range too. This router is second from the bottom on range tests but should till do your work. Dial into the router by typing 192.168.1.1 into your browser window. You will have to login using the user name "admin" & the password: "password".When logged in go tho the setup table and change the range from local to distant. Not all routers have this option. Mine does, so I'm hoping yours does too.
Mar 26, 2010 | Linksys Wireless-N WRT150N Router
Computer connects to internet only sometimes and im in the same room as the router. I try to repair and diagnose and it says a network adaptor may be bad. Its done this since day 1 and I cant stay online...
A common problem I have come across using wifi in a domestic setting is that of co-channel interference caused by neighbouring wifi routers...ie your neighbours router using the same channel as yours.
Try changing your routers "channel", which can normally be done relatively easily using the routers built-in web interface. If you no longer have the manual, post the routers make and model and I'll send you the link.
Nov 27, 2009 | Toshiba Computers & Internet
Blocking free loaders. I want to block my neighbors from using thier wifi from getting free internet off of mines. How do I set that up?
well, there many solutions to do this, but the most simple, effective ones are:
1. make or change your network (WEP) key so that whenever you connect to your own network, you must enter the key for it to successfully connect.
The way to do this is to go to your router's ip address (if you don't know it, google your router's model and search "[your router's model] ip address"])
Then, after you have logged in to your router's ip address (default username is admin and pass is blank), look around the settings and look for changing your network key. You can make up the key there.
2. In that same router page, there should be a section for firewall. THere, type in your neighbour's computer's ip address to block their computers.
Number 1 is the most simplest and effective way. If you still have problems, tell me your router's model/name/company...it would make it MUCH EASIER for me :)
Jun 15, 2009 | Westell Wirespeed VersaLink...
Securing my wireless network DIR615
the password you entered should prevent people from using yor network unless they have the password. Your network will still show on other peoples settings when they check for networks to connect to, but now you have added a password for your router it should say secured next to it when they try to use your network it will ask them for the password - pin - etc... and if they do not have it then they should not be able to access your router. Why not try to see if one of your neighbours can still access it now you have protected it with a password.
Jan 01, 2009 | D-Link DI 514 Wireless Router (DI-514)
Want to block router so others cant use it
the best way to secure you wireless connection is add authentication on your wireless connection,
if you dont know how to set it up you can call your router vendor support number and ask then to help you set up your secured wireless connection.
Nov 17, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
24 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
