Question about Kodak EasyShare M863 Digital Camera
The screen where you look at the picture is marked up and i would like to replace it
  • 2,517 Answers
Can you please explain me more?
Posted on Mar 23, 2011
Samsung LED tv
The power supply board probably needs to be replaced. Sounds like a loose solder joint on the board
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 05, 2016 | Samsung Televison & Video
Problems with screen
It is due to power supply regulator fault. Check the main power supply regulator section circuits for any damaged [bulged] electrolytic capacitors. Replace the suspected capacitors. When replace an electrolytic capacitor, make sure about its polarity. Like torch batteries, these capacitors also have both [+ve] and [_ve] terminals, and should match it with markings at the printed circuit board, when replace them. If the polarity changes when replacing them, they might burst out. Normally, [-ve] marking will be there on its body. See the example of the suspected component. Both good and damaged. See the bulged capacitor and good one on the same frame.
Bulged [damaged]
Damaged
All of them damaged
good one with [-ve] marking
Good one with [-ve] lead marking..
Jul 12, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Unable to take picture in auto mode. there is a "hand" on the screen in between quotation marks??
Hi, The hand mark on screen prevent you to take pictures. Please get it repaired at dealer then. Regards, Jay
Mar 01, 2011 | Canon PowerShot A720 IS Digital Camera
Picture blurred
blurred picture can be adjusted,and sometimes replacing of crt socket will solve the problem.
this is tricky so i've advice you to follow what i've said strictly.
Open the back cover of your set (make sure that you unpluged the unit first).
Look for the flyback transformer (it has a sunction cup connected to the picture tube).
You will see an adjustment knob on it, it mark focus but wait before touching,mark it with your pentel pen,marking the original location of the knob is important because that is the factory align.
After marking get an screw driver w rubber insulator as a handle to avoid an electric shock,this will be used to adjust the focus on the flyback knob.
Turn on the unit and hooked it up by your dvd player.
Play the dvd so that you will see a picture on the screen.
Pause it with a picture with characters.
Now you can see the blurred picture?
Try to adjust the focus on the flyback back and forth minimal turn only.
There's a reaction?Yes- continue to get a perfect picture and youre done.
There's a reaction?No- back the knob on its original position.
Your crt socket is faulty.
try some helped of your technician or people knowledgeable of disoldering and soldering technique.
Pull the board on the crt socket.the socket which attached to the tube is the one you are going to replaced. I've adviced you to observe first and familiarized what are going to dis-assemble because you will do the same when you replaced a new one.
After replacing your crt socket,picture ok?Yes-you're done
After replacing your crt socket,picture ok?no-picture tube is faulty.........
Jan 02, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Burnt marks in my projection tv. Can it be fixed
if they are burn marks they must be present at all times when the tv is on if they are actually on all three picture tubes(CRT) it might be an expensive repair. Sometimes the burnt mark is only present on one of the three crts, a product of a on screen display left on for too long or the failure of a deflection yoke or something similar. the way you can find out if its a G/B or R crt,is when you get a commercial or a scene with a full G,B or R background you'll see the burnt mark on the screen that is damaged. picture tubes are replaceable but somewhat expensive. good luck and i hope i answer you question to your liking, if so please leave you pos feedback at this site. thanks!
Aug 22, 2009 | Mitsubishi Televison & Video
Can't copy pictures from sd to frame
Follow these steps, Selecting all:
1. Press whenever pictures/videos are displayed (slide show, video, single picture). 2. Press to highlight Select all, then press OK. A confirmation screen appears, then your picture display reappears. A check mark is displayed on all pictures/videos in your current location. 3. To remove all check marks, press , highlight Select / Unselect all and press OK. 4. Highlight Unselect all and press OK. A confirmation screen appears, then your picture display reappears. All check marks are removed. Also, you may download the user's guide at www.kodak.com/go/manuals
Jan 22, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Something impacted the screen and now a shatter mark but no picture
If this is an LCD or Plsasma screen, there is no way to repair the panel, it must be replaced. Post the make and model and I can get you part numbers and replacement cost.
Dan
Jul 18, 2008 | Televison & Video
Looks like pen marks on inside of screen
What you are decsribing sounds like your picture tube or tubes have been scored (permanent burn marks on the picture tube phosphor). The sure way to tell is to remove the front screen and look into each of the three lenses while the set is on. You will see a black image of your pen mark within the picture. Did you recently have problems with convergence or the set shutting down (turing off by itself for no resaon) ?
Nov 12, 2007 | Toshiba 50H82 50" Rear Projection...
Marks on Screen
These are burn marks on one of the picture tube, probably the green one from the looks of your picture (the absence of green will leave red and blue)This happens as the result of some kind of previous failure, hopefully that has been repaired now. However the marks will always remain unless you replace the green picture tube which is costly and which is why they sold the tv. Sorry about the bad news, if you decide to have somebody replace the tube for you make sure they look for what burn't it in the first place it could be intermittant and waiting to happen again to your nice new tube. Although seeing what model this is this tv did like to do this when the convergence failed in which case it looks like that has been repaired already. Good Luck, hope you didn't pay too much for the TV.
Apr 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Kodak EasyShare M863 Digital Camera Logo
16 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
