Question about Cooling System for Volvo S40
Anti-freeze reading in radiator -22' anti-freeze reading in block -16' any reason?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Volvo Master
  • 1,449 Answers
May need a radiator flush as can be core is blocked with dirt or rust.
Posted on Dec 02, 2013
How can i flush my clouged radiator on a 2003 kia sedona
flushing blocked radiator cores is not successful regardless of what cleaning agent is used --simple reason , if the water cannot flow through the cores ,it cannot flush out the blockage
Best answer for a fix is to replace with a new radiator and use the correct anti freeze-anti boil additive in the correct ratio at all times
Nov 05, 2015 | Kia Cars & Trucks
Do you put water are engine coolant in radiator
you can put water in the radiator and it will run fine however if your in an area that gets cold enough that requires anti-freeze use the correct water anti-freeze mixture so the coolant does not freeze and crack the engine block or heads.
Sep 23, 2014 | 2005 Chrysler PT Cruiser
My BMW 318 ti, 1998, overheated, I completely replace the thermostat, I change the radiator temperature sensor, I replace the plastic parts of the radiator, but rolling the car consumes anti freeze, I...
If the car uses anti-freeze without leaking, it is going out the tailpipe. You either have a bad head gasket or a crack in the head or block.
Jul 08, 2017 | Cars & Trucks
Engine warms well, heater fan blowing well, but very little heat comes into cab
It could be one of two things.
1. Bad thermostat. Your thermostat is pobably not opening when the engine warms up. Install a new thermostat and you should be OUT OF THE COLD. If not,
2. Your heating core and radiator is probably clogged. One way to solve this is. Flush out your radiator with radiator flush kit. Pease read your owners manual, (YOU NEED TO USE A SPECIAL TYPE OF ANTI FREEZE). If you use the the green color Presotne anti freeze, It will gradually corrode through the linings of your radiator. And the green color prestone anti freeze will blow out the radiator. So read your owners malual ( I beleive it says you have to use Dextron Anti Freeze ( Pink Color).. Replace your thermostat and flush out your radiator. Then refill your radiator with dextron anti freeze. Also make sure the anti freeze resivor is filled to the proper level.. Once you do all of this, YOU DEFFINITLY WILL BE IN HEAT.. YOU CAN DO THIS YOUR SELF ( iT WOULD TAKE ME NO MORE THAN 1 TO 2 HOURSFOR ME TO DO THIS IN MY DRIVEWAY) OR YOU CAN HAVE THIS DONE AT ANY QUICK LUBE LOCATIONS... HAPPY MOTORING
Jan 06, 2011 | 2003 GMC Sonoma Extended Cab
HOW TO DRAIN COOLANT FROM MY 2004 6.4 ENGINE MOUNTAINEER
Welcome to Fixya
Here's the procedure on how to drain the coolant from your radiator.
1. Prepare what you need. To make the process easier, it would be wise to have everything you need before you begin:
Pair of latex gloves.
Screwdriver or wrench.
Rags.
Radiator Flush.
Coolant.
Funnel.
Radiator cap.
Draining pan.
2. Place your car on an elevated ramp. If you don't have one, you can use a lifter to do the job. This is usually stashed in your car's compartment in the back. Positioning your car in an elevated position will make the draining process easier. Keep in mind that though that despite your car being in an elevated position it should still be in a level or flat position.
3. Make very certain that your engine has sufficiently cooled. Not warm to the touch but really, really cool. This is a safety measure to avoid your skin from being burned or scalded. Pressurized contents of the radiator will most likely shoot up in the air if you insist on opening the cap while the engine is still hot. Ergo, not a good idea.
4. Look for the radiator plug. Now's the time to wear your latex gloves because you are ready to begin the draining process. Feel the radiator plug underneath your car.
5. Take the draining pan. Place it directly underneath the radiator plug.
6. Tug the radiator plug loose. You will then see that the coolant is now draining into the pan. Once the coolant is collected in the pan, do not dispose of it as you would dirty water. Anti-freeze is bad for the environment. Keep within environmental laws and collect the liquid refuse in a sealed bottle and turn it over to the proper waste management venue. Keep in mind that Anti-Freeze is harmful to your skin so make sure none of the liquid refuse touches your skin.
7. Observe the consistency of the liquid refuse. If you see metal flakes and other tiny debris, this is a clear indication that your cooling system might need the hand of a professional.
8. Proceed to remove the radiator cap. This allows the air to circulate freely into the radiator tubes and helps speed along the draining process.
9. Check to see if the radiator cap needs replacing. Part of the reason why your radiator needs draining is that sediments and dirt coming from the cap directly mixes in with the Anti-Freeze and water in your radiator. If your radiator cap clearly shows wear, tear, and dry rot, replace it with a new one, pronto.
10. Tighten the radiator plug. After the initial draining process, tighten the radiator plug then fill the radiator with water to shake loose remaining Anti-Freeze in the radiator tubes.
11. Replace the radiator cap. Once you are done filling the radiator with water, replace the radiator cap.
12. Turn on the engine. This allows the remaining Anti-Freeze to be shaken off your radiator. Allow the engine to run for five minutes.
13. Turn the car's engine off and allow it to cool.
14. Repeat the flushing process until the water runs clear. Use the flushing agent this time to make sure your radiator is truly clean. You will know it's over when the water runs clear.
15. Pour in the new coolant. You may have done this many times over but it still always pays to read the instructions of the coolant product before proceeding. The rule of thumb is 50/50 which means 50% distilled water and 50% coolant.
16. Tighten the radiator cap.
Thank you for using Fixya!
Dec 19, 2010 | 2004 Mercury Mountaineer
What is the coolant capacity for a 98 (97-01) Mitsubishi Mirage? 4 cylinder 16 valve. I believe it's a 1.6L motor.
add 50/50 mix of anti freeze start with a 50/50 gallon then after it warms and stat opens add the additional 1/2 gallon approx. of 50/50water/anti freeze needed to fill the radiator and expansion tank
Aug 08, 2010 | 2001 Mitsubishi Mirage
Walk through on how to replace a thermostat in a 2001 Jeep grand Cherokee
Jennipherbrr,
1. Make sure the car is cold. Remove the radiator cap (press & turn about 1/4 turn to remove pressure in the system) Once the pressure is bled off you can remove cap and leave it rest on the filler opening.
2. Find the petcock on the radiator (the little valve attached to the radiator. You have to open/turn clockwise to drain the anti-freeze. Drain anti freeze below thermostat housing. About 1/2 to 1 gallon.
3. Have a catch basin for the anti freeze under the car. Remove upper radiator hose from radiator and thermostat housing.
4. Remove thermostat housing from engine block (usually two or three bolts in the thermostat housing). Scrap off ALL old gasket material from engine block. Double check and make sure all gasket material is removed from surface. If not the thermostat housing will leak.
5. Install new gasket with some high temp silicone. Place a couple of dabs on the thermostat housing and gasket (the silicone is used to keep the gasket in place) *MAKE SURE YOU INSTALL the thermostat the same way you took it out. Don't over tighten the thermostat housing bolts.
6. Remove the radiator cap and replace the anti freeze you removed (make sure the anti freeze is clean). Fill the radiator to the top of the filler neck and replace the radiator cap (push and turn the radiator cap to the right- like a pill bottle). Start the car and make sure the temperture guage goes up. The guage pointer should be in the middle of the guage.
7. Check the radiator reservoir for proper anti freeze level. DO NOT OPEN THE RADIATOR CAP WHEN THE CAR IS HOT!!! THE ANTI FREEZE IS HOT AND WILL BURN YOU.
Hope this helps
Apr 19, 2010 | 2001 Jeep Grand Cherokee
Hi I have an LG DVD±RW, it used to work properly but few days ago i tried to burn an iso. image it didn't work Device: [1:0:0] HL-DT-ST-DVD-RAM GSA-H55N 1.02(E:) (ATA) Firmware Version: 1.02...
According to the log file, there was a spindle servo failure. The spindle servo is responsible for maintaining rotational speed accuracy. I'd say your drive is pretty much dead. See if you can read a disk in the drive. I wouldn't be surprised if it had a tough time just reading files.
Jan 23, 2009 | NEC ND-3500A DVD±RW Dual Layer Burner
Jeep cherokee 2001 box shape
Check your coolant to see how low a temp it's good for. What u are describing is the failure of a freeze out plug. They are there to protect your block and head from cracking in cold weather, if you don't have sufficient anit-freeze protection (old anti-freeze, or not enough anti-freeze). If the water in the engine freezes, the freeze out plugs are designed to be a weak point, popping out to relieve the pressure of the freezing water, hopefully saving the head and block from cracking. The other reason for failure is corrosion due to, again, insufficient or old anti-freeze. To remove, u just need an old screwdriver and hammer, knock a hole in the plug w/ the screwdriver, pry it out. Clean up opening, install new one w/ block of wood and hammer. Of course, the location of the freeze out plug is what determines how much room u have to do this, so u have to decide if it's easier to pull the engine, or remove the head. It would be wise to pull the engine, and change all the plugs as angelo63 suggest, when done flush the system, adding a 50/50 mix of anti-freeze/water.
Dec 20, 2008 | 2001 Jeep Cherokee
Engine coolant has turned to a gel and engine overheated
The reason that your anti-freeze is gelling in your rad is that the mixture of anti-freeze and water is too weak. this could be because of old anti-freeze(same as oil,it deteriorates over time, usually 2 to 5 years), or there could just be too much water added. I would suggest a cooling system flush, and re-fill with a new 50/50 mixture of water and anti-freeze.
Jul 19, 2008 | 2004 Hyundai Tiburon
Cooling System for Volvo S40 Logo
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
