Question about Saeco Stratos Coffee Maker, Espresso Machine
My machine is a saeco royal digital it's apearing in the monitor that "falta grupo" what shoud i do ?
mirran
  • 515 Answers
SOURCE: Instruction Manual Saeco Royal Digital
I have a instruction manual to this machine.
Best regards
/Mirran
Posted on Oct 06, 2008
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
SOURCE: saeco cappuccinatore
also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Posted on Jul 06, 2008
SOURCE: saeco royal proessional does not get power when i turn on machine
you can check the fuses on the power board..there are 3 pcs of fuse ..check the microswitch on the side door,waste container and the brewing unit...it may solve your problem.
Posted on Aug 17, 2009
EsWorld
  • 1618 Answers
SOURCE: royal machine ventilate
Open the hot water valve to allow the pump to prime.
Posted on Sep 16, 2009
Saeco royal professional, on display it is shown needs "ventilation", where and how to do this ventilation?
Hi!
I have a saeco incanto deluxe, it was same problem, i just "reset to factory settings"
in the menu, and then the maschine worked again :-)
Oct 23, 2011 | Saeco Royal Professional Espresso Machine
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
What is coffee dispenser, i have a saeco royal coffee machine, its screen keeps telling me "COFFEE DISPENSER BLOCKED", can you share me your information, a picture will be most helpful, thanks a...
The dispenser is the brew unit in the back of the machine above the drain tray, open door and remove the black unit within and check the screen above the red o-ring.
Jul 17, 2011 | Saeco Royal Digital Plus Coffee...
Saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Oct 26, 2009 | Saeco Royal Digital Plus Coffee...
Royal machine ventilate
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Plus Coffee Maker, Espresso Machine
go into the menu and reduce the amount of water the machine pumps through
thanks
Coffee fix
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Best regards
/Mirran
Sep 29, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Vienna Caf?© SuperAutomatica: Grupo de distribui?§?£o
remove the service group and soak for a half an hour in a pail with 1quart of water to one cup (8OZS) of bleach.now dry it off outside in the sun or use a hairdryer now try to see if water will pass thru quickly or repeat the to soakit one more time. good luck! ru
Sep 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Stratos Coffee Maker, Espresso Machine Logo
183 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
