Question about Maxtor Hard Drive
Hi, I have an older Maxtor internal IDE HD which I'm trying to access using and external IDE/SATA to USB adapter. I hear the drive spin and the headers clicking but the HD is not being detected. Can this HD be salvaged?
    Top Expert:
  • Maxtor Master
  • 75,767 Answers
Hello
The media has damaged. There is no hope. OK.
Posted on Mar 23, 2011
New 1tb hard drive not recognized in bios
it is like putting a new stereo in a totalled car,
May 29, 2015 | Hitachi Computers & Internet
Wd50000aakb make into a external usb
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.10 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
When I plug my maxtor in, I can hear it "thinking"
use an external usb ide( or if your hdd is sata,then use a sata cable)then insert to a working computer then you can copy your files
Feb 19, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
Computer does not find ext drive it always has in the past I tried it on other PC and still no Help
There are two possibilities: the drive is bad or the enclosure has lost a connection. First try a new data cable (if you didn't do this when you tried it on the other computer).
Next, if you are willing to do this, take apart the enclosure and check for any loose or damaged wires in the enclosure. To check if the drive is good, check the specs on the drive (IDE/SATA), you can use a different enclosure (match the size and internal connection) or a USB/IDE/SATA adapter. With the drive connected to the computer with a different device, see if you can access the drive.
For most external drives, taking apart the enclosure to access the drive may void the warranty. However, a warranty replacement will not include data recovery.
Good luck.
(drive enclosures and the USB/IDE/SATA hard drive adapters are available at stores like TigerDirect.com and NewEgg.com)
Jun 14, 2010 | Fantom Drives 120 GB Hard Drive
My maxtor external hard drive has stopped working. When I plug the power in the light only comes on temporarily therefore i can't use it. Have I lost all my saved data?
My maxtor external hard drive has stopped working.There is a chance that you can recover data using a USB to IDE or SATA Adapter Cable to recover your data they cost about $30 if you cant get hard drive to power with adapter chances are it has crashed there are places that can get data off hard drive but they are very pricey hope this helps.
Nov 28, 2009 | Maxtor Computers & Internet
Is a MAXTOR N256 20 GB HARD DRIVE HD model #92048D8 compatible with laptops? It's an IDE
I would say yes. Most IDE hard drives are compatible, all that's needed is the laptop to hard drive adapter. They come in various flavors.... ide to sata (with power converter), ide to usb, ide to ide (44 pin female to 40 pin male), take your pick. :)
Sep 14, 2009 | Maxtor Hard Drive
Internal HD cabling
I understood your problem there are two different connectors
SATA:
And PATA:
If your computer has IDE (PATA) connectors you need an adapter like this one:
Native SATA Drive to IDE 40-pin Adapter for Most Enclosures
Jul 31, 2008 | Adapters.com Video to Monitor HD-15...
Transferring an internal hard drive to another computer
There are several ways but the easiest would be to use an external USB interface such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the IDE connections to your old hard drive as well as a USB cord to your new PC's USB port. This is of course assuming that all you would want is access to the files/data in the old hard drive.
If your plan is to use the old hard drive as the master (meaning you want to boot from it and use your old OS with its settings on the new PC), chances are you would need to reinstall/repair the old OS since it would not run in the new PC.
If you want to install the old HD as a permanent device inside the new PC, you would need an IDE connector and install the old HD as a secondary master/slave.
If you just need to copy/move files from the old HD to the new PC, the initial method would be your best bet. The interface can be borrowed for a one time use.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 12, 2008 | Maxtor Hard Drive
New Maxtor 3200
Hi, This is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the PS3200 itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
66 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
