Question about Yamaha Full-Size Keyboard
My name is Daphne, and I have a yamaha p150 keyboard. The sustain is not working on it. I have switched the pedals, restore to factory settings, don't know what else to do. Can u help me please?
niceneasy
  • 4 Answers
SOURCE: water spillage on keyboard has modified some notes.
Hi John. Doesn't sound good at all. Your Digital piano is an expensive piece of kit and I would seek a professional repairer to put it right. I would Contact Yamaha Kemble and seek advice.
At the end of the keys are small optical sensors that pick up your keysrokes and turn that into Digital Data. I would suspect that the water has shorted them out and they might need replacing.
UK Technical Support is available by telephone on 0870 4445575 - Monday to Friday, 9am to 5pm (4.30pm on Friday).
Regards
Posted on Jan 02, 2009
SOURCE: Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Posted on May 15, 2009
  • 4090 Answers
SOURCE: The sustain is on all the time.
The pedal activates a microswitch fitted to the circuit board. I suspect for some reason unbeknown to man and spirits this switch has become "stuck" or collapsed. If the latter then it has to be replaced as they are soldered to the board. You coulod open the unit trace the pedal back to the sustain switch and "jiggle" it manually to try and release it. A small amount of WD40 on your finger and rubbed over the pole of the switch( do not spray it) should help it to stay releaased until wanted. If you see corrosion on the board near the switch then take it to a music repair shop as this corrosion is like a cancer and will spread to other keys.Mice piddle is not unusual on keyboards and a great destroyer.
Please rate my help++++Thanks for using FIXYA
Posted on Dec 02, 2009
  • 5603 Answers
SOURCE: i want to plug in a sustain pedal to my very old
Sorry to bring the bad news but the PSR300 does NOT have a connection for a sustain pedal.
It will however recognize a MIDI command for sustain so if you had a MIDI sustain pedal that emitted controller 64 code, you could use that.
It is UNLIKELY you would want to do this as such devices are not readily availablle. If you slaved this from another synth that had a sustain pedla capabilty you could play booth together and use the sustain of the other synth.
Posted on Jan 06, 2010
SOURCE: Sustain pedal on Yamaha DGX not working
Hi, I had the same problem, but I have an easy solution. I am trying to connect an FC5 to a Casio CTK-3000. The problem is open vs closed circuit in the pedal and the way that the casio interprets the info. Paulll's fix is correct, but you do not have to use soldering. Simply remove the cover, unscrew the silver screw, and you will notice that the black contraption that holds the two metal strips has one side that pops off. Pop off this side.
Now, notice that the short strip is on top and the long strip is on the bottom. The way the strips bend mean that the circuit is closed when there is no pressure on the pedal. When you press the pedal, the white knob on the long strip pushes the long strip down and breaks the connection with the short strip.
What you need to do now is remove the two strips and slide them back into the black contraption with the long strip on top and the short strip on the bottom. The white knob on the long strip should be facing up. Make sure when you do this that you hook the short strip over that little horizontal black plastic rod so that it will easily contact the long strip when the long strip is pressed down.
By bending the top (long) strip a little, you can make it so that the long strip does not touch the bottom (short) strip in the relaxed position. Make sure that the ends of the strips where the wires join do not touch each other either. You now have an open circuit in the relaxed position, which is what Casio recognizes as NO PEDAL.
Pop the side piece back on the black contraption and screw the black contraption back in place with the silver screw. Set the spring back in place and reattach the 'pedal'. Make sure that there is enough clearance between the top of the white knob and the inside of the pedal so that the circuit remains open in the relaxed position.
Now, if the two strips are NOT touching each other, when you plug it into your Casio, the Casio will not recognize the pedal, which is good. When you push on the pedal, you will close the circuit and the Casio will recognize the pedal.
If you push on the pedal and nothing happens, then the two strips are not contacting each other in the fully pressed position. Take the unit apart and try again.
If the Casio still recognizes the pedal even though you are not pushing on it, then the two strips are contacting each other at any place along their length. Take the unit apart and try again.
Enjoy your new working pedal!
Greg
PS. If you Casio won't work with your computer, there is a fix out there for that too. It involves removing (or renaming) some files that Logitech loads on to your computer when you install a webcam. Weird, but true.
Posted on Jan 27, 2010
Sustain issue with Yamaha MM8
Your pedal may be the wrong polarity for this keyboard. Different manufacturers wire differently. And some use trs 1/4" and others use ts 1/4". Contact Yamaha customer service to get the correct pedal for your instrument.
Apr 08, 2016 | Yamaha MM8 MUSIC SYNTHESIZER
Sustain Pedal works intermittently.
To start with always best to use the correct power supply these should be readily available from any good Yamaha store. Is the sustain pedal a Yamaha pedal? The plug end of the pedal connect a multimeter across the two connectors and set meter to show continuity. If there is no continuity press pedal, hopefully this will now respond. If not then the break is in the pedal. If meter idea works then it could be the socket on the keyboard, these can work loose on the pcb they are mounted to if they are used a lot.
You could open up the keyboard and look inside checking the solder joints on the socket or simply take to a Yamaha service centre.
You could also try a master reset of the keyboard, hold down the highest note whilst turning on, this will reset to factory default.
Let me know how you get on.
Nov 02, 2015 | Yamaha NP-30 Portable Grand Piano &...
P90 sustain sound won't stop some times when am playing
Check and see if there is a switch on the foot pedal. Check the P-90 menu under footswitch to make sure it is set to sustain.
Feb 25, 2015 | Yamaha Music
I am using an mgear sustain pedal for my yamaha keyboard. The pedal usually works, though sometimes I have to flip the switch on the bottom of it, for whatever reason, to get it to actually sustain. But...
Since you didn't specify the model of the Yamaha I will take a good guess. MOST keyboards of all types default via their internal programming to use a pedal that is either a close circuit or open circuit switch. Basically it is two contacts from a wire that is connected (closed) or normally not connected (Open). When you press a pedal, the contacts either open or close. Your pedal has a switch that can choose either one. Now,.. the keyboard has some internal software that controls how the keyboard "sees" the pedal. It sounds to me that you have to get into the "control" section of the interface on the Yamaha and scroll to the "Pedal" polarity section. You might see it as a - (minus) or a + (plus) icon. See if you can make
one of them a default every time you power up. You see, every time you power up the keyboard, it is sensing something different. One last thought... or question...are you keeping the sustain pedal plugged in? or are you connecting and reconnecting it? The keyboard usually "remembers" or senses the polarity from the last power up. I have had similar issues with the Motif keyboards from Yamaha, but have remedied the issue by digging into the internal controls. Lastly, search the manual that came with your Yamaha. See if there is a section under Pedal or pedal polarity.
Oct 20, 2017 | Music
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Hello- my P95 sustain pedal does not work when plugged in but the sustain works when you disconnect the cord from the back of the keyborad
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
Apr 02, 2011 | Yamaha P95 Digital Piano
When i plug it in to the sustain slot in my yamaha keyboard it makes the notes longer without me pressing the pedal.
You may have a pedal that is ROLAND compatible which is OPPOSITE sense from what the Yamaha requires. The Yamaha takes a NORMALLY OPEN contact.
Some Yamaha keyboards such as TYROS have a parameter that you can set to permit using either type pedal.
Some pedals have a switch to change them to use with either type keyboards.
Feb 22, 2011 | Quik-Lok Quik Lok VP-26 U Sustain Pedals
Hi, i purchased yamaha fc15 sustain pedal yesterday. when i connected this pedal to my Roland E-09 keyboard through foot switch port, it activate Start/Stop button ( of arranger & song controls ) and...
The answer is NO... Roland uses the opposite sense switches on foot pedals... They use NIRMALLY CLOSED and your Yamaha is a NORMALLY OPEN switch.
SOMETIMES you can open these pedals and find that the pedal has the opposite sense switch available and you only have to unsolder and move one wire to make it a NORMALLY CLOSED pedal.
Dec 24, 2010 | Yamaha Fc5 Sustain Footswitch
The Sustain pedal does not work.
When push comes to shove, a factory reset never hurts.
Assuming you'd like to proceed with a factory reset, follow these steps:
This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
1) Press the [UTILITY] button.
2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
5) Press the [EXIT] button to return to the Utility Mode.
Oct 14, 2017 | Yamaha Full-Size Keyboard
Is a sustain foot pedal similar to a tattoo machine pedal?
The sustain pedals have only two wires. Usually they terminate in a 1/4 inch mono plug.
yamaha USUALLY sustains when switch is closed. Roland usually sustains on a switch between the wires when the switch is open.
NO POWER should be supplied BY the sustain pedal... it is ONLY a switch.
Apr 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Yamaha Full-Size Keyboard Logo
97 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
