Question about Kenmore 15129 Built-in Dishwasher
No water supply
My drain was clogged so i took it apart and cleaned it out. when i put everything back together and turned it on there was no water going into dishwasher to run a cycle. john
    Sniper:
  • 68 Answers
There are a few checks. Try the #1 first and then proceed to the next one til you get water. Here are a few checks:
  1. Turn off the supply and disconnect the supply line to the dishwasher, turn the water on to flush the line and to check for flow
  2. If you have water to to the supply line, your problem is the water solenoid. Replace the water solenoid.
  3. Turn off the supply, and disconnect the supply line at the shut off, turn the water on to check for flow.
  4. Shut the water off to the house, disassemblehe shut off, clean debris out of shut off. It may need to be flushed. I recommend using a hose to direct the flow into a 5 gallon bucket while someone cycles the water supply.
  5. Replacement of shut off is next.
Please rate this solution.
Posted on Aug 03, 2008
Sewage backing up into laundry room when we use our dishwasher. We have a septic tank. Both toilets flush fine, and no back up in tub
The drain leaving the laundry room going to the main needs to be cleaned. The first thing you can try is what is called a product called Drain King . This is connected to a garden hose and inserted into a drain where the p-trap is removed from the wall When the garden hose is turned on full blast it will try pushing out the clog You should hear it pulsate first slowly then more quickly as the clog is washed away.he water flowing with Finally you should hear water flowing freely. it helps to use warm water if possible. If that won't work the drain will need to be snaked , Turn off the hose and remove the Drain King by loosening the hose connection Then follow that pipe downhill toward the main drain, and look for a clean-out plug. You can loosen the plug SLOWLY, have a bucket, mop, and rags ready and wear old clothes. Place the bucket under the clean-out plug if possible while slowly removing it Water will come out unless the clog is between the laundry sink and the clean-out. If water comes out when the clean-out plug is removed place your snake drain cleaning device into the clean-out and run until the clog is cleared. then run water through it for a while to wash away any residual residue. Put everything back together and test for leaks.
Jul 30, 2014 | Home
Took apart the washer and dryer and need to put it back together...i have everything except where the clear plastic hose goes
Kristen-follow the hoses-water comes into machine at the water supply valves-hot and cold which go into the tub-then there is a drain pump which is connected to the tub via a hose-the out put of the drain pump is connected to the drain through the back of the machine usually at the bottom and this goes into your houses' drain-follow the hoses and you shall reach laundry success-cheers Denny
Oct 25, 2013 | Frigidaire FEX831CS Top Load Stacked...
Good Morning Sir/Ma'am, We own an LG WM2233HW with an "error code of OE" which means "Drain hose is bent or clogged" and/or "The drain filter is clogged". I have checked both. I straightened the drain hose...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!! !
Aug 30, 2010 | LG WM2233H Front Load Stacked Washer /...
A grainy grit remains on all my dishes. It's in the bottom of the dishwasher when the cycle is over. what is it and how can i fix it
I took everything apart in the bottom of the dishwasher, washed them and put them back together and now have clean dishes. I needed a star head to remove the screws, which I had. A Phillips screwdriver won't work. Food and gunk were clogging the drains and screens, even the spray wands. For the very bottom I used a shop vac to get all the dirty water out and then cleaned the small drain.
Jan 20, 2010 | Maytag Dishwashers
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Jul 08, 2008 | LG WM-1832C Front Load Washer
Dishwasher will not drain
We took it all the way apart and cleaned it really well in the bottom of the dishwasher. Then we put it back together. Then we removed the hose from the disposal and suctioned it with the wet/dry vac to remove any clogs, then put that back together.
Ran dishwasher with Tang in both powder cups to clean it, and it's running fine now.
Apr 20, 2008 | Dishwashers
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Washer won't spin
Maybe when you were behind the machine, you did not refit the outlet pipe at the correct height; this is a height approx. 3 feet from the ground or more. Your pump pumps the water OVER this height.
You said it does not spin; you shd check out your outlet filter and clean it. If this is clogged the machine will not spin. All the best!
Nov 06, 2007 | Frigidaire GLTF1040A Front Load Washer
Kenmore 15129 Built-in Dishwasher Logo
206 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
