Question about Refrigerators
Whirlpool Gold Model GS6NBEXRS00 - Ice maker not functioning. The water runs fine but no ice is being produced. I've dropped the temperature after reading that could have been a problem and a small amount of ice was produced but it freezes in the ice maker and never is pushed out into the ice bucket / container. Do I need to replace the entire ice maker unit (part # 2198597?) Thanks.
SOURCE: ice maker from whirlpool gold
check and see if infrared has burned out
Posted on Jun 30, 2008
  • 105 Answers
SOURCE: Whirlpool Gold Ice Maker problem Model # GS6NBEXRS00
I hate to ask the obvious but is your water supply turned back on since the filter change?
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Feb 10, 2009
  • 583 Answers
SOURCE: ice maker freezing up
its a confirm defrost timer problem.the defrost timer is a device which after every interval of 8 hours defrosts the freezer part if the timer is faulty it wont defrost and go on over freezing.you can buy the defrost timer for aprox 30 dollars from link below:http://www.repairclinic.com/thanks and plse do not forget to rate the solution.
Posted on Jun 12, 2009
SOURCE: ice maker stopped making ice. water works fine
chande the filter
Posted on Jul 12, 2009
aasc
  • 1606 Answers
SOURCE: Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Posted on Aug 16, 2009
Ice maker is not producing ice. Water dispenser is working fine. On Whirlpool Gold Model #GS6SHAXLS03
If the ice maker is not refilling with water after its last harvest that points to the=> W10408179 Water Inlet Valve. If the ice maker just sits there with ice and does not empty into the ice bucket we will need to test the 4389102 Ice Level Control
Instructions on how to test can be found HERE If you have something else happening here please let me know, Sea Breeze
If the ice maker is not refilling with water the side of the water control valve that fills the ice maker is defective and you will still get water from the dispenser. The parts I listeed above are for your GS6SHAXLS03 refrigerator.
Oct 15, 2013 | Whirlpool GS6SHAXLS Side by Side...
Not making ice
What is the model number of your unit?
Nov 30, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
