Question about Garden
I have an indoor well in my lounge.It is 3 metres deep and 1.15m diameter. It is lined, filled with tap water and is lit with 120w lighting close to the bottom. The water is cloudy and I wonder what if anything I can do to improve this? Thanks Mac Williams
  • 56 Answers
It sounds like you are having issues with algae. Introducing chlorination or a UV sterilizer will clear it up fairly quickly.
Posted on Mar 23, 2011
Testimonial: "Thanks for the info. I will try your suggestion"
How do I install spalding basketball hoop in the ground with concrete and how deep do I dig?
Dig below frost line, depends upon where you live, but at least two feet deep. I would make the hole about a foot wide. Pole diameter 3-4 inches in diameter.
Aug 10, 2014 | Spalding Sport & Outdoor - Others
Vertical cement pipe 6mtrs deep in ground, 60cms in diameter. How do I get the volume of water in litres?
The volume of a cylinder is pi*l*r^2, where l is the length and r is the radius (and pi, of course, is about 3.14159).
pi * 6m * 0.3m^2 is just under 17 cubic metres (17 m^3). A cubic metre is 1000 litres, so the volume is about 17,000 litres.
Feb 26, 2014 | Office Equipment & Supplies
How can i clean my Tefal maxi fry deep fat fryer
Hi there, the best way I have found to clean a deep fryer is to empty it of the oil and fill it up with 1/3 water and detergent, turn it on but dont close the lid, or if you do close the lid carefully monitor it otherwise it will spill over and let the water boil after about 10mins turn it off and wipe away the ****, empty the water out fill it again with just water, same again for 10mins, empty it and wipe it clean with a cloth
Jan 10, 2012 | Tefal Kitchen Appliances - Others
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
Amounts of Solutions
From the manual:
1. Remove the Clean/Solution Tank by lifting it
straight up, then away from the Lower Body.
2. Unscrew the black cap at the bottom of the
Clean/Solution Tank.
3. Add one of the BISSELL Advanced Cleaning formulas
for Deep Cleaning machines to the formula fill
line on the Clean/Solution tank. Fill the rest of the
tank with hot (not boiling) tap water to the water
fill line. Replace and tighten the black cap.
4. Place Clean/Solution Tank on Lower Body.
The manual is available at retrevo.com, but you have to register to get it. It doesn't open up so that I can link you to it. It doesn't cost anything though.
Hope this helps!
Dec 08, 2008 | Bissell 1770 QuickSteamer Upright Vacuum
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
