Question about Dryers
Need to replace belt on model #leq332ds0 but have no idea how to. Ordered the belt, actually 2 to be on the safe side, and am ready to do any disassembly. Any step by step would be of great help. Thanks in advance.
  • Dryers Master
  • 8,220 Answers
Unplug the dryer. Use a putty knife to pop the top. Unplug the control quick connect, remove the controls, and get the front panel off. Remove the small hatch in the rear so yall can install the new belt. Check the glides and bearing in the rear for wear. The glides break off and pinch the drum then the belt breaks. So check all that.
I have a late model service manual and more HERE
Posted on Mar 23, 2011
Testimonial: "Just the way you said it would be. Worked like a charm. I appreciate your time, effort and helpful information. Thanks!"
Replaced belts on both drives but it still won't play or turn tape at all. Any ideas?
With the belts off, hit the rewind, forward and play switch. Check to see if the deck reels spin without the tension of the belt. If they do spin without the belt then you wll need to replace the motors. They are weak and dying. If not spinning at all with or without the belt then you need to check the motors independently to see that they work with a power source. If that is the case then you need to identify the wire or power board that is not sending power. Hope this helps.
Apr 19, 2016 | Audio Players & Recorders
Why does my frigidaire leq332ds0 sound like it's overloaded when it's not?
Good Morning Nikki,
I understand your Frigidaire dryer, model# LEQ332DS0, is squealing like it's overloaded, even after replacing the belt. There could be a number of possibilities that could be causing your appliance to squeal. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine what is causing your appliance to squeal. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Dryers
Adjustable feet
Hi, The feet are able to be lowered so they are flat to the machines bottom. If you have all ready done this and it is still to tall, then you will have to take the feet off. It may not affect your warranty, but i would check with the manufacturers to be on the safe side.
Kind regards
David
Dec 14, 2017 | Bosch Dishwashers
Kenmore 96272100 won't spin, but heat comes on....
Broken belt most likely. I looked at your model number and your belt number is 341241. Your actual model number with prefix is:
110.96272100When ordering parts you always add the 110. Anyway to replace the belt you first remove the filter. Then you must remove the 2 screws that hold the filter housing to the top because you gotta raise the top. To raise it you grab the dryers back side right behind each hinge and pull the whole top forward a bit while lifting on the front of the top to release the front portion and rotate it to the back. Then you will need a small screwdriver to assist in unplugging the door switch. Then remove 2 screw holding the front on and LIFT up the front to keep from damaging the bottom clips which are flimsy. Once the front is out of your way get the drum out and inspect the rollers. You can lube them with zoomspout oil, it is safe for appliances.
MY PICTORIAL AND VIDEO
Dec 13, 2012 | Kenmore Dryers
We have 52
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
Kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
Dryers Logo
476 people viewed this question
Top Dryers Experts
