Question about Cameras
How do i sync and set up the impact r616 radio slave receiver?
KD-R616 wiring diagram?
Drew, KD-R616 wiring diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
JVC KD R616 Instructions Manual
http://pdfstream.manualsonline.com/c/c2fdda73-62c0-4be2-8de4-4829af7d168f.pdf
https://www.google.ca/search?q=KD-R616+wiring+diagram&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwi3jbu1ttrOAhXJA8AKHSxpBmUQsAQIHA&biw=1024&bih=681
Aug 24, 2016 | Car Audio & Video
I have jvc kd-r616 but when it was connected it came up with protect and n I can't do anything
Check your connections. You apparently have a short in the speaker wire.
Aug 01, 2014 | Car Audio & Video
Jvc bluetooth
try this link
Dec 18, 2013 | Car Audio & Video
Error code 02-66 when I try to use my ipod with my pioneer head unit
I fixed it! I had a working set up. I synced my iPod touch and update the software, then hooked it back upto my car stereo. I received error code 02-66. I disconnected the iPod and cable from the radio. Turned off the radio restarted the iPod. Turned radio back on with main menu displaying on iPod I hooked it back up to the Pioneer radio. Vuala! It works. Hope this helps.
Aug 09, 2013 | Car Audio & Video
JVC KD-R616 wiring colour instrutions
dan go here install manual has everything you need to know trouble shooting also http://www.jvc.co.nz/assets/pdf-manual/KD-R616.pdf
Mar 10, 2012 | JVC Car Audio & Video
Im trying to connect two rc-50 via midi! I want one of the them to act as a master and the other one as a slave. The goal is to have both machines working independently but have all loops on each rc-50 to...
While you can probably get the functions sent by MIDI to transfer to the other unit, syncing PROBABLY isn't going to work very well because there is a lag to form the MIDI sync clock (serial data) and then receive it, decode it and do something with it.The transmit time is about 1/3000 of a second and receiving is at least that much time. On rhythm things I have found the ear can hear 1/1000 of a second easily. If one could set the machines to use an EXTERNAL sync clock and drive the SAME clock to both units, you might be able to sync them together time wise as they would see the sync at identical times.
Apr 14, 2011 | Boss Rc 50
Dont have the handbook as my son threw it away now cant set radio stations cant set anything without the book
Try this link and click on one of 3 manuals listed for PDF download.
http://books.jvc.com/booklist.asp?Model=KD-R616
Feb 06, 2011 | Car Audio & Video
Canon Speedlite 580 EX II
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Dec 27, 2008 | Canon Speedlite 540EZ TTL Flash
Cameras Logo
95 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
