Question about Brother SE-270D Computerized Sewing Machine
When I push down on the thread cartridge, it won't go all the way in and then the threader pops back up. This has never happened before.
    Scholar:
  • 89 Answers
Lets start with this. Make sure your presser foot is up and the needle bar is in the up position aswell. Also make sure that the thread spool is the right size for the caset.
nate
Posted on Mar 24, 2011
15000 Needle treader is a joke,does not work.I have had nothing but headaches with it from day one. I have had the machine for three years. Love everything else about the 15000!
Some needle threaders are not designed very well. Since I've had a machine without a threader for so many years, it does not irritate me so much to manually thread--although the threader is nice when there is one that works! To help with threading the needle, it helps if I lick my finger and swipe it across the back of the needle eye. The moisture attracts the thread into the eye, making it easier to thread. (Works on hand sewing needles too!) Another thing is to place the tip of thread above the needle eye where there is a groove in the needle, then push the thread down the groove and it should go right into the eye.
Nov 03, 2017 | Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
How to fix my automatic needle threader, it will not pop back up, its stuck down?
A needle threader is delicate because it is very thin metal. It is likely that it is bent slightly. If it is threading then move the piece that moves through the needle and check moving parts while it is inserted. This way you can move the metal that is rubbing just slightly to get better movement. You may want to put just a very small amount of oil on the moving parts. If this doesn't work then you will need to replace the threader. Give this a try in order to save money.
May 31, 2014 | Janome Sewing Machines
Auto threader wont come all the way down...makes a poping noise
Personally, I wouldn't bother to fix it. Take a sharp pair of scissors and trim the end of the top thread at an angle and poke it through the eye of the needle. Autothreaders are usually the first thing to break.
Jan 25, 2014 | Brother Sewing Machines
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
Thread puckers and has loops , the threader clicks when it goes up and down..I thionk I bent the top threader?
Threader that goes up and down? Is this the uptake lever? I don't know how this could happen unless the machine was dropped.
Lift the presser foot and re-thread the machine to see if the stitching improves.
Always thread a sewing machine with the presser foot up.
Mar 20, 2010 | Sewing Machines
My auto thread component is not egaging the thread down to the needle.
Need more information. Is the auto thread component going down to the needle? Is
it missing the needle hole? If this is the problem, make sure that the needle position is in the correct position by pushing the needle position button. This will bring the needle to correct height for the thread to be inserted. I had a problem similar and it was because the needle was not in the correct position. When using the thread insertion press it slowly and watch to see where the insertion part is going.
Oct 29, 2009 | Brother CS-8150 Computerized Sewing...
How do I theard the needle on the 5050C singer machine?
does the machine have a needle threader? first if so, pull it down and put the thread behind the left side of the threader and loop the thread around toward the needle then go behind the finger of the threader hold the thread back against the needle and slightly pull upwards pull the threader forward and gently let go with the right hand of the thread and the needle will pull the thread through, second if the machine doesn't have a threader, the easiest way to thread a needle is to buy a needle threader, it is a device that you put through the eye of the needle and put the thread through its hole then just pull the threader back out and the needle is threaded.
Aug 22, 2009 | Sewing Machines
Brother CS-80 will not always thread the needle when I depress the thread cannister.
I get this problem too. I found that it might be because I've moved the wheel while sewing previously and the needle doesn't go back to where it's supposed to be to be auto threaded correctly. To solve it, I just push the canister down until the threading parts are lowered. Once I see where the threader is positioned, I use the wheel to adjust the needle height to where the threader is, then I push the canister down all the way, and the needle is threaded. Hope it works for you!
Feb 22, 2009 | Brother CS-80
Automatic threader mechanism keeps sticking and a part falls off
These machines are nothing but TROUBLE and always will be. Get rid of it. Save yourself much time and frustration.
Apr 22, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
