Question about Salton Melitta MEK17W Electric Kettle
Where can I buy a new scale filter for Melita kettle MK816L I live in the Pickering Ontario area. Thank you
  • 19 Answers
Filter failure is a common problem in Melitta kettles. The filters have a flimsy plastic mesh that falls apart with use, but the filter frame can last as long as the kettle. Some filters are no longer available from the manufacturer. If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh. This is specifically for the MEK17W model but it should work just as well for the MK816L.
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
Posted on Nov 30, 2013
  • 519 Answers
Hi supergran27 :-),
Here's the phone number and location of Salton agents nearest to you.
Pickering Town Centre
1355 Kingston Rd. #70
Pickering, ON
L1V 1B8
Phone: (905) 421-9864
For other agents in Ontario region, click on the link below.
http://www.salton.com/customer-care
Best wishes,
Graeme.
Posted on Mar 23, 2011
White sed iment from ice cubes
This is limescale as you must live in a hard water area, and I expect you also get scale in your kettle. You need to descale the ice-maker if you have one, or if it is from a mains water tap, you can use a under-sink filter, a Brita Jug, or buy bottled water to make ice. The calcium is actually fairly good for you.
Aug 29, 2017 | Dishwashers
I need to buy filters for the spout. Where in the San Jose area are they available?? Melitta MEK 17W electric kettle.
If you can no longer find this scale filter online or from the manufacturer, then you can still repair your original one and make it better than new! This fix has worked perfectly on my MEK17W kettle and it turns off properly when the water boils.
Buy a piece of 3"x3" 100 mesh (150 micron, must be stainless) on Ebay - under $3 inc shipping. Carefully cut the old plastic mesh out of the original filter frame with an exacto blade and very lightly sandpaper the triangular face of the plastic frame that faces into the kettle. Then temporarily hold the stainless mesh to this inside face of the filter frame with a couple of clothes pegs and use a pencil to mark the
triangular outline of the mesh so that it will fit flush against the plastic and also be no wider than the frame. Carefully cut the triangle of mesh to size with scissors. Thoroughly mix up a small portion of 5-minute 2-part epoxy glue (Loctite or JBWeld) with a thin wooden coffee stir stick and apply just a smear of glue to the frame. As soon as the glue starts to get tacky, gently fit the mesh to the frame and clip it there lightly with 5 plastic clothes pegs, 2 on each side and 1 at the bottom. To ensure their release, you can first wipe the pegs (where they pinch together) with the faintest skim of Vaseline or sewing oil. Let the assembly set for 24 hours and then carefully ease off the pegs. You will now have a filter that will last longer than the kettle.
Oct 09, 2011 | Salton Melitta MEK17W Electric Kettle
Where can I buy light bulbs (120V/30W) (part F612E5H01AP) in the Toronto Area - I actually live in Pickering.
hello,
the closest place to you is Accufix Appliance Service 29 Skyridge Road, Toronto, ON M1E 4N7, Canada (416) 283-7447
Thank you and thanks for using fixya.
Jun 01, 2010 | Panasonic NN-H504WF Microwave Oven
Melitta MEK17W Electric Kettle: The little filter that fits into the spout disinte...
Call 1-800-233-9054 and ask Salton/Toastmaster for part number 31036 for the MEK17W kettle. You may as well buy 2.
When this scale filter in the spout of a Melitta MEK17W or Toastmaster TEK17W (identical kettles) gets torn the kettle does not hold in enough steam to trigger the auto off switch. Same thing happens if you do not fully close the kettle lid. With a new and spare scale filter you will get way more life out of this inexpensive and handy kettle.
If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh:
May 06, 2010 | Salton Melitta MEK17W Electric Kettle
I am cheesed off with having to throw away otherwise perfect electric kettes after six months because the spout filter has disintegrated. I live in a high chalk area and the kettle I have at the moment is...
Get one at Best Buy; get the 2 year service policy for 8 bucks. Set an akarm on some computer/PDA thing for 102 weeks away. If, by some miracle, the thing lasts that long, bring it back and get a (free) new one. Oh, get the policy on the new one as well!
Oct 25, 2009 | Faberware Farberware FSU236 12-36 Cup Urn...
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
How to descale Philips HD 4651/C Electric Water Kettle
Not having received any solution message from FIXYA contributors, I consulted with a family member
and also my long held Time-Life Books, Fix It Yourself Library, Volume: Cleaning & Stain Removal,
ISBN: 0-8094-7400-X, Copyright 1990. My issue was resolved by using white vinegar and soaking the internal problem area for 30 minutes. The appliance has cleaned up like new and works fantastic. I apologize for bothering you.
Nov 27, 2008 | Philips HD4651 Electric Kettle
Salton Melitta MEK17W Electric Kettle Logo
459 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Robert Plante
Kolbrun...
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
