Need wiring color code for wharfedale pro evp-15pm cone and horn
4 Suggested Answers
SOURCE: 1994 Crown Vic need wiring schematic for the complete horn system
I tore appart the steering wheel, got the wire color codes, and fixed it myself. Rather easy, once I could see it. all Fixed!
Posted on Nov 10, 2009
SOURCE: need bass cones for wharfedale
I'm putting some on ebay this weekend
Posted on Sep 25, 2010
  • 89 Answers
SOURCE: Wharfedale Modus one six -
Yes, you can bring it to electronic repair shop to rewind the coil. or buy it in the electronic shop. if they don't have same brand you can replaced it with other brand same size and same watts of speakers. thanks
Posted on Apr 30, 2011
I have a flashing code of 3-4 what is it
David,
DTC 3-4 at idle means the EVP voltage is above the closed limit.
Translation: The EVP sensor (EGR valve position) is unplugged or the wiring between it and the computer has an open. The EVP sensor has a 3-wire plug on it, and you can find the EVP on top of the EGR valve (that's the metal mushroom between the intake and a pipe coming from the driver side exhaust manifold (on a v-8)).
It's also possible that the EVP sensor is bad (open).
Good luck.
Mike M, 35-year Phord Phixer
Nov 17, 2014 | 1995 Ford Bronco
What color wiring for horn on a 2003 saturn ion
Have you pulled the fuse for the horn? That might work for you. The color for the wire is black. I would try the fuse first, there is one under the fuse box under the hood. The horn fuse is in the # 20 slot.
Jul 19, 2014 | 2003 Saturn ION
Wharfedale Modus one six - one woofer cone is cracked. It still plays, but needs to be replaced. Where can I buy a replacement, or is it possible to repair the cone?
Apr 30, 2011 | Wharfedale Modus One-Six Speaker
Want to know where the horn wire from the horn switch
Unless your color code is changed, switch to horn is blue. the horn is grounded at the horn. There is also a switch to power wire that is orange.
Apr 19, 2011 | 1993 Harley Davidson XLH Sportster 883
Nov 09, 2009 | 1994 Ford Crown Victoria
I need radio color codes for a 2001 fordranger
The simplest way to figure out wire colors on the ford is to purchase the radio wiring harness from a stereo shop like a Metra or Scosche harness and match the aftermarket wiring color code to the opposite side (vehicle side) of the radio plug. If you are just replacing speakers, then removing the speaker from the car with the plug attached, you can easily figure out polarity. Just connect a 9v battery to the speaker leads on the speaker (NOT THE CAR) for a second will make the cone either pop out or **** in. When the cone pops out, note the polarity of the + on the 9v battery. This is the positive for the speakers. Hope this helped.
Aug 03, 2008 | Car Audio & Video
Tweeter "drive" out on wharfedale svp - 15
Hi bertsteenrt
Can you check the resistance of the HF driver(tweeter). If it is open it will need a new diaphragm. Most of these speakers use a lamp to act as protection for the HF driver. Sometimes these lamps fail. You will need to pull the horn out of the cabinet to check, and the rear connection panel off to get access to the crossover where the lamp is located. Get back to me here and I can talk you through fault finding the speaker.
regards
Graeme
Mar 21, 2008 | Audio Players & Recorders
62 people viewed this question
 Grubhead
Grubhead
