Question about Jaguar Heating & Cooling
My car ac is not getting cold. Put in new high pressure hose and fuse.
    Brigadier General:
  • 4,736 Answers
Did you also recharge the AC Compressor with new refrigerant gas? If not, that's the problem.
Posted on Mar 23, 2011
  • 10,421 Answers
Hi, There is air trapped on refrigerant line. Please release it and add refrigerant and retry.Check also recommended refrigerant for your air conditioning system. Regards, Jay
Refilled 97 jetta ac to capacity it cycles compressor on off remove some runs continous never gets cold
check high pressure with a proper machine and see how many bar you have ,think compressor may be on the way out .
Nov 10, 2017 | 1997 Volkswagen Jetta
My 98 Aurora blows air and ac light turns on but no heat is coming out. What could be the problem?
Heater core sounds clogged take the two heater hoses off (usually easiest on eng side) just put garden hose pressure thru both sides till comes out clear reconnect hoses top off antifreeze... Hope this helps!!!! Good luck!!! Remember if the car is hot there will be pressure on the hoses!!!!
Nov 19, 2011 | Cars & Trucks
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
My truck wont blow out any hot air, just cold. i put a new radiator and thermostat in it. it is full of anti freeze
Try removing the Heater hoses from heater tubes(be careful not to break heater tubes off) then back flush heater core with garden hose(Don't use a lot of pressure). Jell from antifreeze builds up in the heater core and blocks the coolant flow. If it is easier, remove the heater hoses from the engine, that is safer. Back flush the heater from the hoses. To Back Flush (The hose coming from the water pump is the inlet)(Hose going to Manifold is outlet) Back flush outlet hose! To much water pressure may cause damage to heater core!!!! Do Not ues AIR!!!!
Sep 28, 2010 | 2001 Chevrolet S-10
2006 maxima not blowing cold air. What is the first thing I should check before taking it in for a $99 diagnostic. Thanks
Check fuses, also if you can or have some one help you check for freon pressure, that will also disable the a/c compr. Go to a small indepened repair shop they will do this check for much less.
Jun 16, 2010 | 2006 Nissan Maxima
Ac not working
1st you must check for correct refrigerant levels in ac system, must be done with a/c guages, you have a pressure switch that senses correct pressure in a/c system if you are low in refrigerant the a/c will not come on. if you have good pressures high side 70-95 low side 70-95 depends on ouitside air temperature, with the engine off then look at the switch in the high pressure line, jeep also has a fuse in the fuse box under the hood and a a/c relay please check those too. I hope this helps. (red is high side hose- small fitting plug , blue is low side- larger fitting If ac is working and compressor is on good pressure ranges from high side the red hose 160 to 230 depending on temperature outside; low side blue hose 27-46 low side depending on outside temperature, Wear glasses to protect your eyes. I hope this helps good luck
Sep 10, 2009 | 2006 Jeep Liberty
1996 Buick LeSabre AC Stopped Working
The first thing to check is if there is enough gas. The compressor will not work when the gas is low. There is a small inspection glass on the line. This needs to be clear. If you see streaks or bubbles means the gas is low. Never mind the pressure or wiring for now, Add one can of gas and this should get that first part done.
Jun 29, 2009 | 1996 Buick LeSabre
Where do I recharge ac at
there are 2 ports one for low pressure and one for high pressure. the low pressure is bigger in diameter and is usually close to the dryer and or fender and firewall. the high pressure is near the condensor on the fron of the vehicle. if there are caps for the ports low will be blue and high will be red. low side pressure should be 35-50 psi and high pressure should be 135-150 psi
May 11, 2009 | 1998 Dodge Dakota
Heating & Cooling Logo
158 people viewed this question
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
