Grundig GUSR91DAB, when turned on it displays 'time not set' and will not access DAB. No indication of how to set the time was given in the manual.
2 Suggested Answers
SOURCE: How to work / setBuch radio alarmclock
I just found my manual for the Sharper Image SI785 CD/Radio Alarm Clock with Sound Soother. Had misplaced it for quite a while. Am not saavy enough to know how to post it online, but if anyone needs one, just email back your address and I'll be happy to send it. I remember how frustrating it has been trying to program/reprogram one without it. Looking forward now to knowing how to use this thing :)
Posted on Nov 18, 2008
I bought a Bush digtal/ AM/ FM radio ("retro transistor" style). DAB reception dropouts lasting several seconds each time have started occurring recently. AM/ FM is ok.
Constant usage of DAB should not cause it any damage ever. The dropouts are very characteristic of a poor signal reaching the DAB tuner, as digital is either there, or not there, nothing in between.
Check the aerial connection if any, the rod antenna if any, and try moving the antenna (whatever it is) to a better location, usually higher up, away from thick walls, and away from speakers if any.
Apr 18, 2015 | Grundig FR200 AM/FM/SW/DAB Radio
Need schematic for the FR-200
no schematics online but here is manual. try contacting them for schematics:
http://www.etoncorp.com/upload/contents/307/FR200_manual_lowres.pdf
Hope this helps
Sorry I couldnt be more specific.
Apr 13, 2011 | Grundig FR200 AM/FM/SW/DAB Radio
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
Users manual copy of a Grundig satel.antenna positioner AP 201 ?
Do you still want it ?
I have copied it on pdf
tvsateq@gmail.com
Oct 08, 2009 | Grundig FR200 AM/FM/SW/DAB Radio
Replacement antenna
I drcided to replace the radio.
Oct 01, 2009 | Grundig FR200 AM/FM/SW/DAB Radio
Safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set with the button ''1'', the second number of your code can be set with button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons the value indicated in the screen will be increased by one. So if the first number of your code is 5 then you have to push the button ''1'' 5 times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an actual sticker which is in the format you describe. You'll need to remove the unit from the dashboard to be able to get access to this.
Apr 20, 2009 | Car Audio & Video
Clock
Radio can be on or off. 24 hour clock only (11:00pm = 23:00hrs). 2 clocks Time I and Time II. Select one or the other by pressing TIME 1/2 button (shows in display at top center). To set, if it is 23:00hrs, press 2 3 . 0 0, then immediately press TIME 1/2 button.
Nov 11, 2007 | Grundig G4000A FM/AM Radio
Grundig MFW 82-2501 no picture or sound
If you are getting the initial 'pang'(!!!???) noise, then it looks like a cold solder in the Horizonbtal Oscillator or Hor. Output stages. The set is trying to power up, but the Horizontal Oscilator is not 'booting' up. Since it is a new set, it must be under warranty....Get it checked by the company Technician.
Aug 24, 2006 | Grundig GF70-600 TV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
