Question about Danby Dehumidifiers
My Danby dehumidifier leaks out of the bottom. Water not draining into the tank but around the tank therefore out of the bottom between the tank and the dehumidier itself
  • thecat688
    thecat688 Aug 16, 2012
    OMG! I just unclogged my dehumidifier! Until I read this post, I thought my 9 year old dehumidifier was toast! Thank you Thank you Thank you!!!!
    Brigadier General:
  • 4,736 Answers
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
Posted on Mar 23, 2011
  • mikecosco May 29, 2011
    brand new leaks on floor
Water is leaking out of the bottom
I get this complaint once in a while , most times it boils down to a unit that's being used on a Non level surface , most units are designed to gravity drain , if its not level , then Gravity is pulling wrong direction on unit so it drips on floor ;not in bucket
drips also can come from a frozen evap coil , this is a sure sign of blocked air flow and possible gas charge over heat (leak) unplug unit for 48 hrs to see if water continues to drain out , if so yep it's iced up
Jan 01, 2014 | Danby DDR586R Dehumidifier
My danby dehumidifier is suddenly leaking from the bottom .. I have a hose that runs down my drain in the basement .. It was all working great until a month ago .. now there is water leaking from...
Turn the unit OFF and unplug it. Disconnect the hose from the outlet on the unit. Using a plastic 18" Zip Tie, that will fit easily into the drain outlet, carefully insert the Zip Tie and insert it as far as you can. You will reach a bend in the tubing, so gingerly work it past that bend. Once the Zip Tie has reached as far as it will allow, start pulling it slowly back out, while rotating it. This will dislodge any clogs, so be ready for water to follow. It also would be wise, to clean out the tube or hole that drains into the bucket, as it may also have a clog in it.
Hope this helps you to solve the problem, Joanne.
Apr 27, 2011 | Danby DDR600R Silhouette Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Watwrleaks out of the bootom of the dehumidifier -
There should be a drain hose to drain water!!Check tank for leaks or obstructions-check that drain isnt clogged!!un clog and clean as necessary!!! Best of Luck!!!!
Jun 24, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Jun 10, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water tank still gets full when connected to floor drain
Check the fitting where you connect the drain hose to. It may have a plastic seal that must be cleared out in order to use the hose drain. The plastic seal can be easily punched out.
Jun 07, 2008 | Danby DDR600R Silhouette Dehumidifier
Danby Silhouette leaking
check that the removable bucket did not alter a water guide near the cooling fins
Jun 05, 2007 | Danby DDR600R Silhouette Dehumidifier
Danby water tank
this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
Aug 04, 2006 | Danby DDR451 Dehumidifier
Dehumidifiers Logo
8,243 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
