Question about Apple 13.3 MacBook Intel Core 2 Duo 2.4GHz, 2GB/250GB/SuperDrive - Black Mac Notebook
When I connect my Macbook to an Epson 410W the computer screen periodically changes to blue and then back again. It almost seem as if it is scanninng for something.
  • bassist96 Mar 29, 2011
    Forgive me, is the Epson 410W a printer?
  • lhock Mar 31, 2011
    An Epson 410W is a projector.
    Problem Solver:
  • 5 Answers
This is done by all Macbooks when they connect to a display. The computer is setting itself up and fixing the resolution and size issues, so that the image will display correctly onto the second monitor (the Epson 410W)
Posted on May 10, 2011
Pink center in middle of Epson projector display
You have a problem with the blue UV filter. It has degraded. The UV is no longer being blocked and it has cooked the blue LCD chip as well.
Repair may be possible. But unless your projector is worth at least a grand or more then it is probably not economical.
Sep 04, 2014 | Epson PowerLite 410W LCD Projector
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
I watched a movie earlier on my epson projector with my macbook. but this evening all it shows is a blue screen and I have tried very much to get it going. I think some how now my mac in not connecting to...
You may have disconnected the projector while your laptop was about to go to sleep. Try (force) restarting the computer by holding down the power button for a few seconds, wait til it shuts down, then power-up again!
Aug 14, 2010 | Apple MacBook Mac Notebook
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
My Macbook Pro wont boot - stays on the blue screen
The fact that the "BONG" sound (or better known as the MAC CHIME) does come on and nothing further means that the computer cannot find your hard drive or (sometimes worse) cannot find the operating system. This means that you will have to remove the hard drive... then insert it nice and firmly again. Try now to boot. If nothing happens then your drive has gone faulty and it could mean that you may have lost your data... NOT NECESSARILY though.... What I mean by that is that you may still be able to access the dat when you connect the "faulty" drive to another computer via USB with an external casing and then get your DATA off it.
Jul 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Epson scanner 1250 software won't install on Macs w/ OSX10.5.6
See that must be an internal issue of your system either your system is corrupt or the driver is not properly installed.You need to install it properly and for more guidance on this issue just get in touch with technical support team of Epson and get connected by dialing 1-800-243-0019 and get your issue resolved within a short period of time
Aug 31, 2017 | Epson Perfection 1250U Flatbed Scanner
Macbook - BLANK SCREEN!
Itunes is very tricky and its freezes computers very badly.try to take out battery and than turn on computer slowly,Soon if you can you need to reinstall itunes maybe to start to work better.
Jun 04, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
EPSON STYLUS CX3900 MacBook MacOS x tiger
I use the CX3800 talking to a printer connected to a PC on a network and it seems to work fine. You can also download drivers from OSX from epson's web site
Jan 08, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Apple 13.3 MacBook Intel Core 2 Duo 2.4GHz, 2GB/250GB/SuperDrive - Black  Mac Notebook Logo
239 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
