Question about D-Link DES 1024D (DES-1024D) 24x10/100 Mbps Networking Switch
My D-Link DES-1024D can't assign ip addresses to client computer automatically anymore. how will i resolve it?
  • 83 Answers
You switch does not provide DHCP services (assigning of IP Addresses). That is done by either your router or a server on your network.
Posted on Mar 23, 2011
How to reset settings of DGS-1024D
n that case you have to rest the router. There two ways to do so:
Method1:
There is a small button at the back of the router labbelled as reset. Its very narrow you need to press and hold it for about 10 - 20 sec using a needle or any sharp objet.
Method2: If you are not able to find the button. You can use a we-based portal to do so. Connect your computer to the router and enter the IP mentioned at the bootom of the router in your internet browser. User name and password will be provided at the bottom of the router somewhere next to the IP address. Once you log in you can reset the router from there.
default IP: 192.168.1.1
Aug 09, 2013 | D-Link DES-1024D Express EtherNetwork...
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
D'Link DES-1016A
assign them an IP address each, making sure the addresses are all different and consecutive, make sure the subnet mask is the same on all machines, the switch will work right out of the box.
Jun 07, 2012 | D-Link Computers & Internet
No console port on D-link DES 1024D switch....how to see the configurations of the switch?
please try here:
manual source:
ftp10.dlink.com%2Fpdfs%2Fproducts%2FDES-1024D%2FDES-1024D_ds.pdf&rct=j&q=D-link%20DES%201024D%20switch&ei=ovVUTtePJe-GsAL-jrW9Bw&usg=AFQjCNFCXB5yxOjc5WcpSoSUGKmCpiJGag&cad=rja
Description
With Plug-&-Play functionality, the D-Link DES-1024D Un-managed switch expands your network and automatically detects your network speeds and adjusts for peak performance.
http://www.dlink.com/products/?pid=75
Aug 24, 2011 | Computers & Internet
I have dlink switch model DES-1024D i need default IP address
The default IP address for most D-Link switches is 10.90.90.90
Jun 13, 2011 | D-Link DES-1024D Express EtherNetwork...
What is the default IP address of D-LINK DES-1024D 24-PORT 10/100 Ethernet switch and how can it be reset? its unmanaged version! mine is stuck on 169.254.180.130, while my routers has a 192.168.1.1. only...
This issue is more on a hardware. 169.254.XXX.XXX refers to an INVALID IP ADDRESS. Here's what you can try:
>release the ip address by running command prompt:
>>>>Click START>type CMD on the search bar>type IPCONFIG /RELEASE and hit ENTER
>>>>ip address will be set to 0.0.0.0
>renew the ip address: by typing IPCONFIG /RENEW and hit ENTER
>>>>it will generate new sets of ip addresses
However, if it still gives you 169.254.XXX.XXX you need to flush the DNS by typing IPCONFIG /FLUSHDNS and hit ENTER and it will immediately tell you that the DNS had been successfully flushed.
>Check your ip address by typing IPCONFIG and hit ENTER
That's the best I could do for the issue that you have.Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | D-Link DES-1024D Express EtherNetwork...
Switch D-Link DES-1024R + My problem is not gateways automatic
No It's not virus . It is issue of ip address in your computer. You can set ip address with 2 method static and DHCP. For DHCP you need to enable it in router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP and enable so you can get ip from router.Enable "ip get automatic in network adapter tcp ip property. If you want to ser static ip in tcp ip then gateway ip set to router ip if your router ip is 192.168.1.1 then your computer ip is 192.168.1.3 subnetmask 255.255.255.0 and gateway as 192.168.1.1 Then you can access internet Let me know if you need further assistance. Thanks for using FixYa.
Jul 19, 2010 | D-Link DES 1024R Plus (DES-1024R+/5)...
I want the default ip address, domain name and password of "dlink des 1024d switch"
Hi,You can get your expected domain name also getting hosting at just $1.99 per year from this http://www.tucktail.com/ site ,visit here for more details.All the best.
May 11, 2010 | D-Link DES-1024D Express EtherNetwork...
I have a D-Link DES-1108 Ethernet switch. I have my switch plugged into my router and i know the cable has connection but it still won't issue me an IP. Auto-negotiation is enabled on my router but it...
To determine if the router or the Ethernet switch is faulty.
Disconnect the Ether switch and connect the computer to the router and see if it connects to the Internet.
Next if you have a couple of computers, connect them to the Ether switch and see if the computers can communicate with each other. You may need to configure the LAN cards with a fix IP address (say 192.168.0.XX each computer must have a different XX number). Remember to change the TCP/IP configuration back to Obtain an IP address automatically and Obtain DNS server address automatically.
If these test are OK then the problem is the connection or route configuration. You do not need a crossover cable between the router and switch.
Get back to me with the results of the tests then I can advise you what to do next.
Nov 10, 2009 | D-Link DES-1108 8-Port Ethernet Switch...
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like 192.168.0.xxx. If you have an IP address like 169.254.xxx.xxx you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link DES 1024D (DES-1024D) 24x10/100 Mbps Networking Switch Logo
537 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
