Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Memory card error SDHC Toshiba - Canon PowerShot SD550 / IXUS 750 Digital Camera
  • 262 Answers
I've checked out your Canon Powershot SD550, and this previously written answer definitely applies to you, Wendy:
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Posted on Mar 23, 2011
Lexar 4gb sdhc memory card error
Are your computer's card reader and camera compatible with SDHC cards or only with SD cards? While SDHC cards will fit into SD devices, they are electronically incompatible and will not work in devices not designed for SDHC cards.
Jul 15, 2013 | Lexar Memory Card Sdhc 4gb Class 4
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Nov 26, 2011 | PNY Attach? 16GB USB 2.0 Flash Drive
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
Toshiba type "A" sd card
I beleive the memory that it can read is only limited by the software you are running such as windows XP sp1 and 2 can recognize upto 2gb SD cards but keep in mind that SD cards only go to 2gb anything bigger than that are SDHC and are the same size but designed differently so the reader must be able to read SDHC format. Note if your hardware is capable of reading SDHC cards and your software limits your ability to use anything bigger than 2gb you can still insert and use upto 2gb of space on an SDHC card that is, say 16gb so that is how you can tell if it is hardware or software that limits the use of an SDHC card.
Jun 02, 2011 | Computers & Internet
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
What kind of memory card does this camera take?
i checked specs on that camera and the maximum memory card you can use is 512mb. if you get one that size you should have no errors anymore
Feb 19, 2009 | Toshiba PDR-M700 Digital Camera
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
271 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
