Question about RCA TruFlat 27F520T 27" TV
Our 2004 rca tube tv screen went recently went out on us. When you turn on the power, you can hear the tv and you'll only see a blue line in the middle of the screen that shrinks and fads out and the tv eventually turns off completely. We cannot see anything on the screen besides the blue line and only for about 3 seconds. We would like to know how to fix this in the cheapest manner possible. I looked online before and it said something about the tact switches possibly needing replacement? I'd also like to do this myself. Is this a common problem? If it is the tact switches, how do I go about ordering these and how much are they? Thank you, Ryan
    Top Expert:
  • RCA Master
  • 75,452 Answers
Hello
It is reparable problem. You see a blue line across the middle of the screen I thinks and posts this solution. The fault is due to the absence of vertical scan. In your set, there is an IC used for this purpose, and it has been dead short now. That is why you see the line at the begining, and it disappears a few minutes after. The vertcial output IC can be located at the main printed circuit board, usually screwed on to a metal heatsink to sink away the heat genereted in it while working. You can easly located it by the following method.
Look at the deflection coil, the coil fitted at the neck of the picture tube. From which, four wire will go towards the printed circuit board, and will be pluged on to it with socket. Just draw out the printed circuit board from the TV and turn it upside down. Look for the connections that I have menttioned earlier, four of them, out of which two of them will be for horizontal scan, and two of them will meant for vertical scan. Follow the vertical scan track, can be identified by two wires emerges form the board, will be connected via copper track and will go to the vertical section, from which you can identify the vertical IC fitted neareby it, usually will have 7 or 9 pin vertical type one.
There is no need to check it now, because, it has already been shorted and damaged in your TVs present case. Desolder it out from the board, and go for a new one of same type and number, replace it as the previous IC was, will solver your proble.
You must have a desoldering pump, a soldering Iron, solder wire, some knoledge in electronics,and more comecentration and patience. OK.
Posted on Mar 23, 2011
How to hard reset rca 27F554T
The means the deflection is not working, there is a coil of wire around the neck of the tube, it is run by a transistor. This transistor has probably gone bad
Nov 24, 2017 | RCA TruFlat 27F520T 27" TV
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA SCENIUM MODEL # D52W136DBYX1
If it's normal television, with CRT picture tube . then it's Blue gun which went off normally its a solid state circuit which can malfunction. which is located at the back neck of picture tube blue gun out put circuit a transistor or a resistance of 470 K or 390 K Ohms can blow off. or the tube base can loose contact with the blue gun pin.
Feb 06, 2018 | RCA D52W136D 52 in. TV/DVD Combo
RCA D52W20 - turns on and off, blue screen, tech said need picture tube
It does sound like the tube, have the shop use a tube restoration machine to rejuvinate the tube, and replace the eprom to try to correct the no power down situation.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
It very well could be the Blue CRT shorting out. However the not shutting off is not a symptom of the tube being shorted that sounds more like a signal board issue rather than a picture tube, as the signal board can cause all the symptoms you have described.
Aug 26, 2008 | Televison & Video
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Jun 14, 2008 | RCA D52W15 TV
TV went blue
either shorted picture tube or blue video output circuit
Apr 21, 2008 | Toshiba CX36G60 36" TV
Blue screen
Sounds like a bad blue crt.,which is one of the tubes
Mar 20, 2008 | RCA D52W19 52" Rear Projection Television
Blinking red power light - set will not turn on
Were the pale blue lines real thin in a slight diagonal from bottom to top of your screen? If so you either have a bad component in the blue drive, Blue CRT socket or your Blue CRT is shorted.Try removing the blue CRT socket and trying to power up your set for a moment without the blue socket attached to the tube. Be sure the CRT socket doesn't touch any components when you try this. Let me know if the set starts up without the blue.
Jan 23, 2008 | Televison & Video
Rca 52" projection tv...d52w20
You could have a bad red tube or the socket on the tube may be bad; completely different from convergence
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TruFlat  27F520T 27" TV Logo
150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
