Question about Refrigerators
Okay, the water has a stale taste even after installing new filter. kenmore 50524101
  • 10,421 Answers
Please use only recommended filter for your kenmore. The taste of the water will depending your water source and of course the filter.
Regards, Jay
Posted on Mar 23, 2011
Stale ice after a new water coil is installed
The water became stale inside copper lines feeding ice maker most likely. Dump your ice for a few times until this clears you should have ask for some money back for copper poison, (joking) Thanks,Sea Breeze
Feb 23, 2012 | Kenmore Refrigerators
My ice taste like plastic
if there is a filter change it or use more of the water so it does not sit too long and get stale
Aug 03, 2009 | GE GSS20IEP Side by Side Refrigerator
Coffee tastes stale even after cleaning
A few things you can do. Buy less pods at a time and store them in a jar. Shake or aerate the water when you put it in the unit. Don't put it in, the night before.
Jul 26, 2009 | Philips Senseo HD-7810 Coffee Maker
ICE CUBE MAKER SMELLY ICE CUBES
your model will have a filter for it. it is located usually on the fridge side torwarss the top back of the fridge. it sounds like you need to replace the filter. it needs to be replaced every 4 monthes or so to keep the water clean. also you may put some water in a cup from the tap/faucet and make sure it is not the water it's self. if it is you may want to think about also having a water filtration system installed in your home.
Jan 07, 2009 | Refrigerators
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water and ice has a funny taste
THANKS FOR YOU QUERY JACK.FIRSTLY DEPENDING ON HOW OLD THE APPLIANCES IS MOST MANUFACTURES USE THE SAME OR SIMALAR WATER FILTER SO THAT WILL BE YOUR BEST BET TO CHECK WITH THEM.NORMALY WEN THE ICE AND WATER TASTE FUNNY I HAVE FOUND THAT IT IS WHAT WE CALL ICE BURN AND THAT IS NORMALY WHEN THE ICE HAS GONE STALE OR IS STANDING FOR A LONG TIME TO SOLVE THAT IT IS BEST THAT YOU USE THE ICE UP AS SOON AS POSSIBLE.HOPE THAT THIS SOLVES YOUR PROBLEM.
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
Mar 06, 2017 | Kenmore 56872 / 56874 / 56876 / 56879
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
