Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water
Kenmore Ice Maker
Ice Maker is making clicking noise
  • Whirlpool Master
  • 8,220 Answers
Ice cube stuck in mold. Solution get out the hair dryer and heat up the mold till it harvests. Time will tell if the maker starts doing right again but I bet you it does!
Posted on Dec 17, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
Posted on Oct 24, 2007
Bgillespie
  • 89 Answers
SOURCE: Ice maker
Replace ice maker!
Posted on Dec 16, 2007
SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
This is a Whirlpool made Kenmore there fore from what your telling me about your ice maker I'm pretty sure it's the ice maker motor module. If you take the cover off the ice maker you will see a large white gear in the center is a little two headed pin to keep the gear in place, if the pin is broke or twisted in any way that is your problem and you will need a new icemaker motor module. Check first and let me know then I will tell you how to install it, it's VERY easy and only takes 15mins. Hit me up when you find out hope I helped.
Posted on Jan 24, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
My ice maker does not eject ice when frozen. Make
Good day,
Unplug refrigerator.
Snap off front cover of the ice maker. You will see a large white gear.
If the plastic gear has a screw in the center, then you can remove the gear and inspect for broken teeth. The gear is easily replaced thru any appliance parts house.
If there is no screw then the ice maker uses a semi-solid circuit board and must be replaced.
Dec 17, 2009 | Kenmore Refrigerators
Ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Jul 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker is making a creeking noise
I went in and knocked all the ice out and it started to work just fine.
May 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water Logo
155 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
