Question about Lincoln Electric Welding Tools
Lincoln Powermig 350MP welds for a short time and then stops with a fault code 81 ,which does not appear in the owners manual
  • Doug Miller
    Doug Miller May 30, 2018
    This helped me. Thanks!!!
  • 407 Answers
Hi:
Code 81 mean an overload to the system, this problem occurs when the wire is not running freely from drive rolls to the contact tip. To avoid this problem do the following troubleshoot.
1) Make sure you have the right size and type of drive rolls for the wire you are using. P.e. if you are using steel core wire (gas use) you need U-grooved type, if flux core wire then you need knurled type.
2) Check your tension at the idle roll pressure setting, this one must be 3-4 if using metal or flux cored wires. Less for aluminum and more for S.S.
3) Check your liner if there is any kink on it, change it.
4) Change your contact tip if needed.
5) Check the tension on your wire spool holder, this one also must run not so freely but free enough to avoid wire nesting.
Hope this help.
If this was useful to you please vote. Thanks.
Your wire must run smoothly
Posted on Mar 23, 2011
Lincoln weld pak 100, no heat penatration on the D setting
I believe your voltage control rheostat (potentiometer) must be worn out. Check your owner's manual for the part number and request it, it's not expensive and it is an easy part to replace. If you are doing that would be a good idea to do the same for your speed control rheostat.
Or clean them if you can, take off all the carbon particles that it build up with the time.
Mar 20, 2014 | Welding Tools
Mig 350mp error code 214
I went through this and lincoln said could be the feed head board but the service man that I ended up taking my machine to went through all the pin connections and tighter them all up and so far it has never coded again.
Apr 01, 2013 | Lincoln Electric Welding Tools
Astro power powermig 110
Ebay is a maybe. Guns are somewhat interchangeable, so it might be better to get the gun which has the tips available more readily.
You might try your local welding shop first, followed by an online vendor who carries perhaps Tweco, Northern Tool, Enco, Harbor Freight maybe.
Sep 20, 2012 | Welding Tools
I have a lincoln power mig 255 and every time i weld little holes appear in the welds. what could this be?
Hi:
This could be a problem of gthe gas you are using. Make sure to use mix 75/25 argon/CO2 for mild steel welding, argon 100% for aluminum and trimix helium/argon/CO2 for stainless steel.
Also check your heat (voltage) 16-22 is enough for weld of most steels less than 1/2 inch.
Aug 06, 2011 | Lincoln Magnum 100L 10' 025035
We have a Lincoln welder - JER type SA200 code 39-2, serial #TEF 9978, that will start but will not arck can you give us any indication what might be the problem
Hi:
The problem must be the fuses, these ones can be damaged due to an over voltage or over heating. Check your owners manual for the fuse location.
Aug 02, 2011 | Lincoln Welding Tools
350mp with 25ft. python push pull all of a sudden black carbon sute both sides of weld this welder has always been a great welder sent to dealer but came back same we are welding 4043 .035 aluminum wire
I had this problem with another brand,but the same solution should be effective on your Lincoln. All I had to do was clean my inert gas opening at the "stinger",allowing more argon to shield the weld. If this fails you may have excessive oils or paint residue at the joining edges. Good Luck!
Jul 13, 2011 | Lincoln Welding Tools
I lost the owners manual to my lincoln weld pac#100 welder
hi mack:if you call or emal lincon customer care department theyll be happy to send you a owners manual to give you your gas shield capablitys ,thats what there there for.the customer. hope this helps jojogunne
Mar 10, 2009 | Lincoln Welding Tools
Warning light
That is the check-engine light. It means something has failed and caused a fault code to be stored in the car's computer. Take the car to AutoZone and ask them to do a code scan (it's free) - if you do this at a dealership, they'll charge you an hour's labor. Have them write down the code(s) for you exactly as they appear (such as Pxxxx, where the x's are numbers), and then post the codes up on here as a reply to my message. Then we can start the diagnosis.
Oct 02, 2008 | 2004 Lincoln LS
Welding Tools Logo
1,612 people viewed this question
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
joe_jochoa
Level 1 Expert
ray gallant
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
