Question about HP Scanjet 3400c Flatbed Scanner
HP Scanjet 3400 C
I cannot clean my glass inside the HP Scanjet 3400 C.
How to open the casing to release the glass ??
Gerhard Fuetterer
  • 1 more comment
  • william_cv01 Aug 12, 2008
    Scanjet 3400C
  • nocturne6 Sep 05, 2008
    I would like to open the case to clean the dust from the inside glass of the scanbed. It is making spots on the things i scan.
  • Anonymous Oct 06, 2008
    I had the same problem with my 3400C and actually managed to get it open. I lifted off the cover/lid and it lifts right out at the hinges. inside the hinge area are plastic latches, i used a flatblade screwdriver to depress that and it released. Then I could see some of the same type of "snap in" latches along the sides of the case where the top snaps to the base. I just used 2 very small thin flat blade screwdrivers from my computer tool kit and very gently worked my way down the sides opening them. Putting together again was the easiest part. Just be real careful and gentle with the side latches. Patience will win out. Mine is clean and now scans beautifully.
    It is obivous that HP does not want users to be able to fix this themselves, but it is possible. I did it. and I'm a 48 yr old mother of 3, not a technician, just a typist type.
3400c after latches under cover slots, first clip about 3.25 inch next 9.75 inch, along the long sides from latches , then slide out ,use thin driver , like lady said
BUT while in there , take a Q-tip and some 10-30 or what ever oil , and LIGHTLY no not one drip , oil the round bar and a little on the wear surface of the square bar ,this will stop a clicking noise .Clean glass to , never turn a scanner upside down , dirt falls on glass again .
Posted on Jan 15, 2010
Preciso do drive desse scanner pois não consigo estalo só pela usb
Posted on Dec 08, 2008
    President:
  • 2,712 Answers
Unfortunately, The 3400 series cannot be cleaned on the underside of the glass. Scanners with the capability of having the under side of the glass cleaned are listed below.
Posted on Oct 04, 2008
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
How to clean the glass underside of the hp scanjet g3010
working with computers since 1964 (yes, there were computers even then...), with consumer scanners since 1988, servicing hp equipment and scanners since 1998, for saving my life - i never, ever see any smudging on internal surface of the glass... could you kindly elaborate how you get smudging there?
there is no consumer serviceable parts inside, these are "disposable" scanners and never intended to be repaired or serviced inside.
Apr 24, 2012 | HP Scanjet™ G3010 Flatbed Scanner
How do you clean the underside of hp5590 glass?
Detach the ADF assembly. Remove the 4 case screws from the scanner bottom. The case has a notch at the back that has to be unclipped to separate the top and bottom. Clean the glass underside repeatedly, I use methylated spirits on soft toilet roll. Check in the glare of the scanner light, and reassemble.
May 19, 2011 | HP Scanjet 5590 Flatbed Scanner
BLACK LINES APPEAR WHILE SCANNING WITH hp SCANJET
mirrors underneath the glass are dirty or "fogged up" . Remove the glass if possible and clean the mirrors carefully with q-tips.
Dec 25, 2010 | HP ScanJet 2300C Flatbed Scanner
Hi, Im using HP scanjet G2410. when I scan, it is showing one thick black line in the middle of the scanned copy. please give me a reason and solution. Thanks in advance .
This kind of problem - continuous black lines - is usually caused by a speck of grit or dirt on the scanner head. The dirt is immobile in relation with the head, so the latter "sees" black wherever it goes. It's possible that the head is damage, but that is a very rare occurrence indeed, while dust is far more frequent.
You need to remove the protective glass (be careful when releasing the lock, and use gloves if possible - fingerprints may be inconvenient to remove; use solvent-free window cleaning fluid and a little water, in case) and clean the head using compressed air and a soft, lint-free cloth. Then reassemble.
In some models - don't know about the G2410 though - it is also possible to reach the head from two small openings on the sides of the platen glass. You launch a scan, so that the head moves from its resting position until it's nearest the openings. Then unplug the power, thus marooning the head in a reachable position. Most compressed air cans come with a thin straw which will allow you to reach the head without opening the scanner (and voiding the warranty, more often than not). CAREFUL not to invert the air can: the white spray of freezing liquid (it's not really "air") coming out from an inverted air can may damage or permanently stain the scanner head. If the grit is visible and the opening large enough, you may even be able to arrange its removal with a long thin wooden skewer or even a drinking straw.
Aug 31, 2010 | HP ScanJet 2400 Flatbed Scanner
HP Scanjet N6010 Once documents are scanned a line appears on the scanned copy
The lines on a scanned document are typicaly caused by dirt on the scanning glass. To clean it use the following steps.
1. Unplug unit.
2. Open the fron access door from the top.
3. Clean both top and bottom **** glass that run the width of the scanner.
The glass can be cleaned with a lint free cloth and a mild glass cleaner.
Jul 21, 2010 | HP Scanjet N6010 Photo Scanner
HP Scanjet G4050 - Can I clean under the glass?
Yes, but it is not a simple process.
Typically these are sealed and rarely need the bottom part of the glass cleaned. However seems I always get that rare few. :)
You must remove the mounting fasteners. Be careful and make note which positions the fasteners were removed. Each model has different locations. You may even have to pull up a label to reach a few of these. Hidden and tucked away not for the novice.
Try to remove ONLY the ones needed holding the glass in place.
Once you have the glass removed, use canned air or something to blow out the case. Clean glass and reverse the process.
Never EVER spray anything wet inside the case.
Be warned, it is very easy to S-t-r-i-p out a mounting point as you are working with plastic parts. Labels may not lay perfectly flat once you have pulled them up to remove a fastener. Little glue helps here for stubborn spots. Use light weight glues like Elmers.
You do not want the glue that holds like steel. You may have to dive in there again in the future. :)
Oct 31, 2009 | HP Scanjet G4050 Flatbed Scanner
Opening an older HP Scanjet 3300C case ??
I recently picked up a SJ 3300Cse and have the same issue.
On mine, on the top of the scanner near the hinges there are two small white rubber peices that are very well camoflaged. If you remove them you'll see the two screws to open the hinge side of the case.
Good Luck.
Jul 18, 2009 | HP Office Equipment & Supplies
HP Scanjet 4570c/5500c producing dark, blotchy, almost black scans. Has worked fine for years on XP. Reinstalled drivers/downloaded and updated drivers/rebooted/unplugged/replugged USB and power--same time...
Is the glass clean?
Often the plastic will out gas and it will deposit a film on the glass. You might have to open it up and clean the inside of the glass with window cleaner. There is also a mirror in the scanner head. That can get fogged up too (in fact it gets fogged up more frequently than the glass plate). The trick there is to find the mirror below the slot and then clean it with a q-tip that has been dipped in alcohol.
Jul 17, 2009 | HP Office Equipment & Supplies
Disassembly of HP ScanJet 4470c.
You remove the panel that holds the control buttons by putting a small flat head screwdriver under the both outside edges (held by two small pins). Be carefull the ribbon cable does not unplug. After removing the two screws that are under the back hindge slots, the whole top pivots up and off of pins at the front. You feed the panel thru the hole left when you removed it. This frees up the top and the glass on both sides can be cleaned. Hold the glass up to a strong light to be sure it is clean before putting everything back in reverse order
Dec 05, 2008 | HP Scanjet 4470c Flatbed Scanner
HP Scanjet 3400c Flatbed Scanner Logo
1,289 people viewed this question
Seeker5211
Seeker5211
