Question about Whirlpool AWZ412 Front Load Washer
WHIRPOOL washing machine drum out of alignment and making horid noise
    President:
  • 670 Answers
There are no alignment adjustments for front loading washers. The only issue that could exist to make this type of problem is if the spider or support arms that hold the wash drum true in the washer are broken. You can verify this by removing all items from the washer and spinning the wash drum by hand. If it is sagging or rubbing against any part of the washer as it spins, then the spider is broken.
It is an expensive repair, since the washer needs to be taken apart and the wash drum and spider assembly has to be replaced and maybe the outer plastic tub may also need to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Posted on Mar 23, 2011
  • echosinla213
    echosinla213 May 12, 2012
    I think i have the same problem but the shocks look ok not broken i used the washer 2 years before i put it in storage where it sat for 2 more years. the shocks move up and down with no issue just when i tighten the bolts in the back the front of the drums pull away from the door area and shakes to much during rinse and spin cycle.
Haier 1.0 washer makes load knocking noise in spin cycle
. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Feb 12, 2013 | Haier Washing Machines
Kenmore 970C45042 10 washer makes tremendous noise.
Check this link :
Feb 11, 2013 | Washing Machines
My machine is making a noise when it spins then becomes unbalanced what do I do ?
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
Feb 01, 2013 | Washing Machines
So I don't see any issues with the shocks. When I manually turn the drive shaft, it makes a lot of noise. Like the inside drum is out of aligment
Check this link :
Jan 21, 2013 | Washing Machines
Problem with Washing Machines Something stuck /rattling in washing machine plastic divider Inside drum
Check this link :
Jan 02, 2013 | Washing Machines
How do I stop my aav 8000 washing machine from making a rattling noise in spin cycle? It's on level ground ;-\ I disassembled some of the washing machine and the noise is coming from a metal par
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | Admiral Washing Machines
I have changed the brushes on my washing machine, and now it works again, but it has a load wuring noise when the drum is turning why is this.
The motor may be out of alignment a tad putting unnecessary pressure and binding the motor. Try adjusting it a bit. And make sure it did not have spacers that were left out from shimming. Also it could be your transmission.
Apr 07, 2012 | Bosch Washing Machines
I have a Whirpool top loader washing machine model 6ALSQ8000MW3 that makes a thumping/banging noise when slowing from a spin cycle as if the load is unbalanced. I am a fitter by trade and as my extended...
Thank You for using fixya
Aug 30, 2011 | Washing Machines
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
Sep 07, 2008 | Hoover AL130 Front Load Washer
Whirlpool AWZ412 Front Load Washer Logo
806 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
