Question about Bosch Washing Machines
Key symbol lights up - Bosch Washing Machines
    Genius:
  • 1,114 Answers
You have activated the kiddie lock and to open it you need to hold down the start button for about 5seconds good luck!
Posted on Mar 23, 2011
How do I cancel the control lock
It would help if you gave the brand and model number of your dishwasher, but the answer is basically the same. Look carefully at your dishwasher control panel. You probably have a little lock symbol that is lit up (or a light inside the symbol is lit). And usually this lock symbol is located near (usually above) a button that is usually used for another purpose. Most often this is the Heated-Dry key or button. Press and hold this key for 3 to 5 seconds until the lock symbol light goes out. And it's just that easy! But if you press the key, and nothing happens, then you may have a bad control console that will have to be replaced.
Feb 25, 2015 | Dishwashers
Kenmore ultra wash machine won't run even with indicator lights on. Symbol on machine says Lock on
You have the control-lock function turned on. There should be a key located near (above or below) the lighted lock symbol. Usually, it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock your dishwasher and you can now use it normally.
Jul 15, 2014 | Kenmore Dishwashers
LG Enact how to turn light up on keyboard
press Fn symbol key and light symbol on keyboard Function Keys
Sep 16, 2013 | Computers & Internet
Sign of car with key warning light on dash
Here is a fix >
Security and Immobilizer System Indicator Symbols Symbols & Tell-tales
engine_immobilizer.gifsecurity_indicator_symbol.gifThese are Security and/or Immobilizer System Indicator symbols used by manufacturers. One of these symbols lights momentarily to indicate that the ignition switch is locked and will need the proper transponder-equipped key to re-start. The vehicle is immobilized otherwise. Green symbols will flash when the vehicle is immobilized.
lock.gifIf the symbol is visible when the vehicle is on, it indicates a malfunction in the security system. If the engine does not start with the correct key, and the security indicator remains on, the system may have a malfunction. You will need to contact your dealer in either case.
Keep the Symbol meanings with you!
Feb 09, 2013 | 2008 Hyundai Getz 1.3
Have just purchased a 2006 Mazda 6 Atenza and noticed that there is a light on the dashboard that is continually blinking - it is a car with a key symbol in it. I refered to the manual but it is in...
This symbol is normally the car electronic immobiliser symbol and should not be lit once the car is started.
If it keeps on flashing and the electronic immobiliser is installed properly, it will prevent your car from being started.
Flashing symbols means immobiliser code is invalid or uncoded.
Hope the information is useful.
Oct 03, 2010 | 2006 Mazda 6
There is a light flashing with a a key symbol in it. when i put key in ignition it goes off
It's the security system. That is a symbol for the security system of the car, you can deactivate it by placing the key in the key slot.
You should get that symbol anytime the key is away and the doors are closed. It's normal.
Hope helps (remember rated this answer).
Aug 08, 2010 | Toyota Prius Cars & Trucks
Dell inspiron 2200 laptop - what are the 4 lights on top right of keyboard for? the first one is constantly blinking and the others are never lit up
Hi those are your keyboard and status lights
Looking at your laptop from the front the first light on your Right hand side is your scroll lock light and is only on when you press the scroll lock button (the symbol shows a lock with a little down arrow)
The light to the left hand side of that light is your caps lock light and again only turns on when you press the caps lock key (The symbol shows a lock with a A in it)
The light to the left hand side of that is your numeric keypad light (Symbol has a lock with a 9 in it), this comes on when you press the num lock key on your keybaord
Finally the last key is your hard drive light (like a cylinder), this will be flashing most of the time as you use your PC as it is constantly reading and writing data
Regards
Shauqat
Jun 10, 2010 | Dell Inspiron 2200 Notebook
Ten key pad keys are turned on. How do i switch them off
Solution#1: Accidentally pressing Sft+Numlock key combination will activate & inactivates ten key pad. (You'll see light enabled in padlock symbol with a number in it [i.e.beside ALL CAPS symbol on your lap monitor]).
Use: "ShiftKey+NumLock" (NumbLock Key: 2nd panel from Top right on keyboard)
Jan 07, 2009 | IBM ThinkPad R51 Notebook
Washing Machines Logo
29 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
