Question about Acer Aspire L100 PC Desktop
I lost my ACER connect USB for my keyboard and mouse, what do you call this USB?thanks
SOURCE: Acer 5100 keyboard issue
Dear friend.. the same happened to a customer's laptop.
I suggest you do the following:
First, try to scan your harddrive for viruses in another computer (you can buy a cheap 2.5" USB enclosure for your drive and use it as an USB drive). Once you do that, clean from viruses.
Next step is reinstall the disk and boot the machie again.
If it's a virus problem -as it happened to me- the BIOS block itself and nothing responds, so, you'll have to cheat BIOS.
Plug a flashdrive (any kind) and wait to windows recognizes and installs it. Once it's done unplug it and plug a USB keyboard and/or mouse and wait. Once you have control power off the system normally (THIS IS VERY IMPORTANT TO UNBLOCK THE BIOS).
Next time you power on your computer, keyboard and mouse should work great.
Hope it helps.
Greetings, Pablo.
PD: One advice... you will probably have to reinstall windows. And finally try linux... this won't happen with it.
Posted on Mar 14, 2008
  • 10 Answers
SOURCE: mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
Posted on May 05, 2008
  • 1019 Answers
SOURCE: Acer Aspire 5050-5430 USB ports stopped working
I hope i can help resolve your problem for you.
this may be a problem relating to your system device driver files.
Try This:-
go to My Computer/Control Panel/System/Hardware/Device Manager. at the bottom of the page you will see USB.
If you have any yellow symbols ( exclamation Marks ) then the driver has been corrupted, or installed incorrectly.
if you have a system restore disk. this may solve the problem for you. or recovery cd.
If you require further assistance, please ask.
Mike @ compurepair.
Posted on May 17, 2008
SOURCE: my acer aspire 5100 keyboard,usb
O.K If you follow these instructions to the letter ,I can help you get your system up and running again.Acer motherboards have the CMOS battery hardwired in its frame work and cant be changed This is where your problem is.Unlike most other computer brands you can change out the CMOS battery like a watch battery.
First Dont panic.
Now go to a computer supply store and get a de-magnatised computer screw driver set and cpu thermal paste ( artic silver).
Remove battery
Remove all srews from the back of the laptop
open and remove back cover.
Remove the Hard drive,and ram stick
Flip laptap bak upright and remove title bar strip or power bar strip (its the plastic strip above the keyboard) its only snapped in so be gentle .Remove the screws that are visible here.
Remover keyboard and unplug the circuit stip to both the keyboard and touchpad mouse.
Remove the power plug leading to your screen.
Remove the entire keyboard face plate with a few more screws.
Flip laptop back over and remove the fan the cpu heat sink and cpu.
Follow the wires leading from your screen to the clipset.unplug the black and white wires then remove the chipset.Pull the LCD creen wire through the board and remove the screen from you laptop.
Now all that should be left is your motherboard and dvd rom drive.
At this point your going to empty the information being held by your corrupted CMOS battery by FREEZIN IT!!! YES FREEZIN IT. Put mother board in your freezer for no shorter then 10 hours ,taken it out once ever 2 hour for 10 mins to warm then back to the freezer again. This process will clear the CMOS battery.
Now its time to put all back together.
Follow your step backwards until you reach the point of installing your CPU.
Take a cue tip with some rubbing alcohol and remove the old thermal paste from the cpu and heat sink. Now add a tick tak size amount to you CPU and reseat it in its housing (notice the small arrow on the cpu and housing indicting the direction for the cpu to set.) tighten down retainting screws. and install the heat sink.
Finish the process backwards until your laptop is back together.
Turn your pc on and you should be good to go.
I further recommend backing up all data and reformating your drive.Also change any settings in you BIOS to its default levels.
I rate this process a difficulty of 5 out of 10
R.Lee
Tech Specialist
FutureTechPC Hardware Acceleration
Posted on Feb 10, 2009
ghoff1
  • 167 Answers
SOURCE: Acer Aspire 5100-3357 lost function of keyboard, touchpad and USB
hello, this has been one of the most reported problem with the 5100 model. i have 2 of them, and they have done the same thing! one i had 2 find and install a new mainboard-400 bucks! not very cost friendly. i did post a solution more than a year ago, but it is a work around that let me use the acer with the dead keyboard,touchpad,usb- you must buy a pcmcia usb card, it goes in the slot on the left side of the acer 5100. then a usb mouse and keyboard will work. (you can get this cardbus adapter cheap, as 400 bucks is 2 much. these pcmcia cardbus card come with 2 or 4 ports. this will let you use the pc, it has been a great solution for me and a lot of others, been in use over a year like this. acer is no help, unless you wish 2 spend a large amount of $. the one with the new board lasted about 8 months before the usb port stopped working for the second time, i then got a second cardbus usb card and have usb again. sorry for your problem.. good luck! do as i say and the acer will work again.( a problem model) just search for pcmcia usb cardbus you will find many 2 choose from- i picked the ones with the NEC chipset, as these are reliable! be well!
Posted on Oct 24, 2009
I've lost my Acer Aspire Z5710 dongle. Is it possible to find some other USB device to connect existing keyboard and mouse? Maybe there're any third-party compatible dongle manufacturer?
Why can't you just connect the keyboard and mouse to the usb ports on the machine?
You should be able to find the part on ebay or Acer parts for that matter.
I hope this helped.
Good luck and have a fantastic day.
Jun 23, 2011 | Acer Aspire Z5700 PC Desktop
My keyboard neither mouse are not connecting my computer it just doesnt show up i have a remote that connects to the same usb sender perfectly fine but the mouse and keyboard wont. Thank you,
its hardware problem, may be water or any liquid get inside and make the keyboard not work state, do you have any function key to disable keyboard or mouse mean go to control panel -> hardware setting check whether mouse was disable or not, if it disable mean make it enable so that your mouse works good same for keyboard.
Good luck
Dec 30, 2010 | Acer NSK8458AN Keyboard
How do i get my mouse and keyboard to work i push the connect button and it still does not work it did not come with a usb and its the new touch screen acer computer
Some Acer computers have the USB transmitter tucked inside the mouse. You pop it out of there and plug it into one of the USB ports on the computer.
Mar 14, 2010 | Acer NSK8458AN Keyboard
Acer 5100 keyboard and mouse will not work. No
Hello there, this is usually caused by one of three things.
Either something was just plugged in (usually USB) that is interfering that you can just unplug
The computer has locked up for another reason (more in a sec.)
Mainboard could possibly be bad / going bad =(
To test if the computer itself is locked up try plugging in an external USB mouse or keyboard to see if you can get that to work. If it does then that means the keyboard and mouse built in are failing, which again basically means the mainboard is failing.
Hopefully it will be that the computer is completely locked up so when you plug in an external usb mouse or whatever it won't respond. That's easiest to fix.
Please let me know
Thanks
Tim
Nov 06, 2009 | Acer NSK8458AN Keyboard
Unresponsive keyboard + mouse pad
I guess you have a mechanical problem, sounds like the mother board have some issues on starting all devices.
If you could use keyboard to go in the bios, and see the screen, if would be the OS that need to be repaired.
Aug 04, 2009 | Acer Aspire 5100 Notebook
Infrared mouse Mod:MG0570T just stopped working 1 day. I've lost the paper work that came with it so I need help trouble shooting to solve the problem.
my mouse get lost on regularly. First press button on receiver (device plugged inot USB port) the blue led should flash slowly looking for devices. next press connect button on the bottom of mouse. it should connect and start working. If not, unplug receiver, re-plug and try again.
Mar 30, 2009 | Acer Computers & Internet
Keyboard and mousepad
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | Acer 91.63X07.001 Keyboard
Keyboard,sound,touchpad all not working keyboard, touchpad and all usb ports stopped working
kINDLY CONNECT A USB KEYBOARD AND/OR MOUSE TO TROUBLESHOOT THE NOTE BOOK IF USB KEYBOARD/ MOUSE (EXTERNAL NORMAL USB DESKTOP KEYBOARD MOUSE). THEN WE WILL BE ABLE TO TROUBLE SHOOT
Feb 29, 2008 | Acer Aspire 5100 Notebook
Input failure on the above laptop
just try to check your connection may be your usb connection is loss contact....or maybe the cable wire is disconnected...to solve that problem you just try another keyboard and mouse....
Dec 17, 2007 | Acer Aspire 5100 Notebook
Acer Aspire L100 PC Desktop Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
