Question about Vacuums
Opticlick 2 Robot Marie Moulinex - Vacuums
Try to get my gigaset tablet to work
It's a waiting game
What do I do with the green robot on my screen? - Android Forums ...
https://forums.androidcentral.com/.../818224-what-do-i-do-green-robot-my-screen.ht...
Jul 20, 2017 - 6 posts
Welcome to AndroidCentral Are you doing a software update? Does the green robot have a little cog spinning in the middle? If Yes, this is absolutely normal and just wait for it to do its thing. Could take up to 1 hour to install + optimise your apps. (only if you want to) Click Here To Join Our Lovely Forum ... Can anyone help - green robot disaster!
8 Jun 2016
I think I really broke it (please help!)
26 Jan 2015
More results from forums.androidcentral.com
May 07, 2018 | Vacuums
How do robotic vacuum cleaners work?
They continually suck air, when they hit a surface change automatically change direction to clean overall all accesible places.
Sep 06, 2016 | Bissell SpotBot Robotic Wet/Dry Vacuum
What is the best forex robot available and do you recommend?
If you take my opinion then I would recommend you to look for the Plus500 is the best robot. There is forex robot available in the market but I always suggest my friends and family get services from Plus500. I have experienced before and I earn many profits with the help of Plus500 traders. I like their services and offers as compared to others. You can also try it or you can check Plus500 review before taking any decisions. It will be a benefit and easy to you.
Jan 03, 2013 | Vacuums
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
How do I change schedule on Roomba
go to roomba.com when at there site go to customer care support then to pooduct resources then select a robot roomba,scooba,ect find your sereies 700,600 ect go to documents&manuals then to scheduling roomba then to viewing and deleting schedules follow the steps
Dec 18, 2012 | Roomba iRobot 560/561 Vacuum Cleaner...
I have a euralab robot vacuum and it is only lasting about 5 minutes before it runs out of power. I have had it for about 2 weeks and it worked well at first
I can't guarantee that this will solve the problem, but try deep cycling the battery.
Run the robot until it stops completely and uses all of the battery charge.
Charge the battery until fully charged. Let the battery cool for 6 hours.
Repeat and see if the battery life improves.
Repeat this charge/cool/discharge cycle 3 to 4 times.
Gary
Jul 15, 2011 | Vacuums
I need a manual for the Moulinex food processor model 305
This is the link where you can try to find it: moulinex.co.uk/pages/download.
Excatly as 305 isn't there, try with some similar model.
Good luck.
May 27, 2011 | Vacuums
My roomba no longer works on my area rug, it starts backing up continuously once it encounters the rug.
Sorry to read about your problem, I hope this helps you out.
iRobot Roomba Vacuuming Robots and the iRobot Dirt Dog Workshop Robot are equipped with four infrared Cliff Sensors that prevent robots from falling off stairs or ledges. The Cliff Sensors are located along the inside of the bumper. If the Sensors become obstructed by dust or debris, the infrared signal is weakened. Regularly inspect and clean the Sensors. Use compressed air for best cleaning results.
http://homesupport.irobot.com/app/answers/detail/a_id/314/p/5
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Roomba Robotic Floor Bagless Vacuum
I have 2 I robot roomba cleaners they charge but will not turn on. The robot company does not repair them don't know what to do
Hi. It depends on where you are in the world. Companies in the US repair them and so do I in the UK.
But if you are using a new battery and same issue, then the power button is at fault.
Apr 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Vacuums Logo
134 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
