Question about Detlev Schaefer RemoteKeys
There is a security code 21ht3304/05 philips tv remote and does not allow me to set channels and other programmes in the tv
  • 415 Answers
I'm not sure the exact keys but most philips tvs can be reset by CH38 plus holding two keys at once, ie the + and - keys or the Sleeptimer key etc. You might try the first combination there and see if that unlocks it to allow you to set up channels.
Posted on Mar 23, 2011
I have just been given a hand me down Philips Magnavox Smart Plus Series TV, but it is giving me a code, ,and I do not have a remote control, how do I get to channel 3
You may have to purchase a programmable remote control as a replacement and use its code search feature to find a code that will control your Magnavox TV.
Feb 05, 2015 | Philips Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
Have a sony universal remote model RM-V401 trying to set code for a phillips tv
Procedure to programme Sony universal remote RM-V401 to philips TV are
1. Turn on the component to be programmed.
2. On the remote control, press the SET button.
3. Press the appropriate component button for the component being set up.
4. Using the number pad, enter the component's manufacturer code.
5. Press the ENT button.
6. Point the remote control at the component.
7. Press the POWER button to verify operation.
Code for philips TV are 011 043 056
Thanx
Aug 06, 2010 | Philips Televison & Video
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
My remote won't allow me to turn on our TV but after I turn the TV on, the remote allows me to change the volume and mute but will not allow me to change channels.
I would re-program the remote. I don't belive this is the exact correct code. Some codes kinda work but no fully. That's when it's time for another code for your brand or use the setup and power auto-code search
Apr 08, 2010 | Philips Televison & Video
The code to programm my philip universal remote with my toshiba television
code and instructions can be found type phillips remote codes into search bar and choose a website
or press and hold code search button till red light stays on then enter each 3 diget code untill the tv functions codes for toshiba 112 313 413 506 510
512 613 902 after correct entry red light goes off
try channel up down volume after each code good luck ron
Dec 10, 2009 | Philips Universal PH301S Remote Control
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
I purchased a Philips Universal Remote PM3S/PM3ST and can not get the code to operate my Magnavox TV. I tried every code and every possible code search method.
press set
press tv button
then push channel up button, repeat until channels change
press set
press power and see if it goes off
good surfing
Mar 06, 2009 | Philips Magnavox Learning Universal Remote
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Televison & Video
Computers & Internet Logo
223 people viewed this question
Top Detlev Schaefer Computers & Internet Experts
David Payne
David Payne
Are you a Detlev Schaefer Computer and Internet Expert? Answer questions, earn points and help others
