Question about ASUS P526 PDA MOBILE PHONE wGPS RET Smartphone
My sim card network not service, how to repair it
My nokia e63 shows sim card not valid
you need to put in a sim card for the network the nokia is tied to or have it unlocked.
please don't post your imei number on websites or it will be cloned.
May 04, 2015 | Nokia E63 Cell Phone
How to put network on your phone when it does not support any sim card
What is the exact problem with your cell phone? If it does not accept any network's SIM card, then the SIM port might be damaged. You need to get it repaired from any local service center. If it works with only a specific network SIM card, then the device might be network locked. You need to unlock it using unique unlock code. You can get the unique unlock code for your cell phone from Mobile-Unlocker.com at affordable cost with an easy unlocking guide. Good luck.
Jan 08, 2015 | Cell Phones
How do I activate my new phone?
It's the same throughout all brands.... Remove battery cover or any cover holding sim card and/or SD card.
Locate the position the sim card is placed and insert it correctly. Do the same with the SD card if you have one. Put the device back together then switch on. The phone will check your sim card and connect to your network provider (if phone is unlocked to all networks) you will find out quick enough if the phone is locked to another provider, it won't work !
Assuming it pairs with your network, the on-screen instructions will tell you how to proceed, like any email accounts etc that you want synchronised with your device. It should automatically load your previous contacts and will install some updates automatically too.
These are generic instructions for the average type phone, read any manual you have carefully. but this is the general way..... good luck.
One more thing....make sure the device is charged.
Jan 05, 2015 | Cell Phones
Sim card rejected
what is your phone model,brand?If the phone display sim card rejected because of incorrect puk code.You can go to service provider office and get new sim card.There is another reason available for sim card rejected problem.If the phone locked to some network.It display sim card rejected when you insert another network sim card.Check which country and network it is locked now.Get unlock code from the site Unlocking4u.com for GSM network locked phones and unlocked it easily.If it is an iphone get remote unlocking service from the site and unlock it.Then use any GSM network sim card.
Jun 05, 2013 | Cell Phones
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
I have lenovo G560 laptop.in this laptop i saw sim card slot under the battery so how can i use it
The SIM card is for mobile broadband (wireless internet anywhere you have cellphone service).
Before using Mobile Broadband, you first need to choose a mobile networkoperator (such as Sprint, Verizon, AT&T, T-mobile, etc.) and make sure you are in the coverage area of the network.
After that, you also need:• To activate the Mobile Broadband service through your local mobile network operator. Youwill get a Subscriber Identity Module (SIM) card after activation.
Best regards,Abdielcomputer repair plantation
Nov 12, 2011 | Lenovo G560 067999U Notebook
My nokia 3230 do not detect my sim card & do not show network also.Bu it does not show that insert sim..How to repair it??
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.onlinegsmunlock.com/nokia-3230/rs7wp9/
Jan 17, 2011 | Nokia 3230
How do i unlock a sim card with a puk code?
contact the service Provider........
Oct 29, 2010 | LG KU990 Viewty
My phone no.9903378821 sernvice provided by Airtel having of no signal.Showing EMERGENCY CALL ONLY
Switch off your phone, remove the battery and take out the Sim card. Now try it on another working Mobile or alternatively you can try another sim card on your mobile handset. If the sim card is working on another mobile, then the problem is with your handset, if it's neither working on another mobile, then you need to get another replacement. To get a new replacement, visit the nearest Airtel Service Center (any airtel shop), they'll give you another sim card with the same number and without any fee.
In case, your sim card is working on another mobile and another sim card isn't working on your handset. First check the sim connector, if you see that the sim card is detected by the Mobile, and it's only without network, probably, there's problem with the Network IC or antenna switch (another ic) or could be water logged problem. The only solution is to get it repaired from a Samsung Service Center or from any Mobile Repairing shop (I think you are in india, if so, most mobile repairing centers repair almost all brands in one place). They'll easily fix it for you. First they will check the software and then the hardware. If any parts replacement is necessary, they'll do it for you with a small fee.
I wish you good luck.
Thanks for using FixYa.
Aug 11, 2010 | Cell Phones
What is the meaning of cdma? is it normal sim card
In cellular service there are two main competing network technologies: Global System for Mobile Communications (GSM) and Code Division Multiple Access(CDMA). Cellular carriers including Sprint PCS, Cingular Wireless, Verizon and T-Mobile use one or the other. Understanding the difference between GSM and CDMA will allow you to choose a carrier that uses the preferable network technology for your needs.
for wiki answar http://en.wikipedia.org/wiki/Code_division_multiple_access
Aug 10, 2010 | Cell Phones
ASUS P526 PDA MOBILE PHONE wGPS RET Smartphone Logo
Top ASUS Cell Phones Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you an ASUS Cell Phone Expert? Answer questions, earn points and help others
