Question about Whirlpool Microwave Ovens
Microwave manufactured July 2009 --- Just stopped heating. Still runs but food/drinks are ice cold no matter how long you leave them in or how high the temperature????? Everything else still works fine - clock, light, timer --- just doesn't heat.????
  • Whirlpool Master
  • 8,404 Answers
There is no temper selection per-ce. The microwave is either 'on' or 'off' as it heats. Temperature is related to time selected.
Do you frequently open the door to check the contents while the oven is running? Most people do. When you do this, you invoke the door safety interlock system. This system protects you from dangerous microwave radiation. With the door closed, there is no danger.
What's happening? When you open the door with the oven operating, you open the tiny contacts on the little micro switches that make up the safty interlock. As such, you send a spark through them, burning them a little bit. A little bit added to a little bit added to a little bit adds up to quite a bit and eventually, they fail. When they fail, they are not able to signal to the oven that the door is in fact closed. If the door is not closed (forget what you know about the door) the magnatron will not energize thus no heat. This is, in my experience, the #1 reason for a microwave to fail.
Remove your cover, find the switches and verify their proper operation with a volt/ohm meter. If you call a serviceman to do this for you, expect to pay $100.00 and up. Of course, if you dont know what a micro switch is, don't have a VOM or how to test, this will be money well spent.
Be aware, there is a device inside the cabinet that if you touch the terminals, it can seriously injure or kill. It is the small can, usually silver, that has two terms on the top. It 'stores' electricity in the thousands of volts. DONT TOUCH IT.
I hope this answers your question. Thanks for your question @ FixYa.com
Posted on Sep 19, 2011
Food does not heat
it sounds like your magnitron has gone its what heats the food up or it could be the high voltage transformer you will have to take it to a repair shop that deals with microwave as they give off alot of raidation and if any of the parts I mentioned are gone can be expensive might be cheaper to buy new one
Dec 12, 2011 | Microwave Ovens
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Won't Heat Food
My Kenmore 721.63259301 would not heat items up so I came here and saw the parts required and was just about to order them when I checked the online owners manual and found this. FULL FIVE-YEAR WARRANTY ON
THE MAGNETRON For five years from the date of purchase, if the
magnetron in this Kenmore microwave oven
fails due to a defect in material or workmanship,
Sears will repair it free of charge.
My microwave has a manufacture date of July 2009 so I will be taking it right to the closest Sears repair center for a free repair. I suggest everyone do the same.
Aug 18, 2009 | Kenmore 63792 Microwave Oven
Constantly runs but does not heat
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
May 17, 2009 | GE Microwave Ovens
Microhood is not heating, otherwise functions normally
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 03, 2009 | Microwave Ovens
Samsung MD800SC Microwave runs but stopped heating
Chances are you have a bad connection, maybe the cook relay or at the magnetron, but feel free to write back with details when it fails again.
Aug 19, 2008 | Samsung MD800SC Microwave Oven
Mircowave oven stopped working
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 27, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
