Hi, I have a Hoover Washer/Dryer, model ref HNWL6136 1300RPM. The problem is that there is no heat on the drying prpgrams, and I'm not sure if the water is heating on the washing cycles. Everything else functions as it should, and there are no blockages. I guess that the heating element has packed up, and would like to know how to test this, and if a relpacement is a feasible DIY (ie just how difficult is it to fit)? Thanks in advance John
  • 2 more comments
  • jhe_uk Mar 31, 2011
    Hi Ginko,
    Sorry, I am not used to this system, and had intended to reply, but it seems I hit the wrong button.
    I had hoped for advice specific to my type/model washer/dryer, not a generalisation, albeit that your advice is appreciated. Secondly, you only addressed the issue of testing, and if I test and find fault I need to know that repair/replacement is a task that I can takle, and how, with my limited electrical knowledge?
    Step by step intstructions would be preferred, please.
    Regards
    John
    Ps If I find that the safety fuse has blown, will I not then have to find out what caused that event?
    Thanks for your advice. My machine is a washer/dryer, not a standalone dryer, is your advice equally applicable?
    As I originally mentioned, there are no blockages, programs work and water drains away very well, but the water does not heat, and there is no heat on the drying cycle.
    I would appreciate step by step instructions, specific to my machine, to test parts and to replace any defects.
    John
    I just sent you a reply, but cant see it anywhere, have you received it?
    John
    Looking for a Hoover Washer/Dryer expert with access to diagrams etc, please
    John
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
  • 10,319 Answers
The most common repair on dryers is to thoroughly clean out the excess lint in the dryers venting tubes. They collect moister as well causing a sensor inside the dryer to shut down the heat
Make note the the filter that catches the lint only absorbs about 95 percent of it
The remainder is stuck inside the tubing making the exhaust to back up
This back up of exhaust is well detected by a moister control sensor that was a government regulated part manditory installed in every dryer built in the past decade. This was issued to prevent house fires from dryers with this issue happening
  • Washing Mach... Master
  • 19,396 Answers
Hi.
The heating element is not the most common reason for no heat. The heating element is a thick impedance, and does not break too easily. The bi-metal thermostats used in the heating group fail quite more commonly.
Before testing parts, check the thermal fuse. You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat or heating element.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
If there is a lint filter, clean it and eventually replace it. A dirty lint filter may cause overheating and the thermostat will blow.
Regards.
Ginko.
Posted on Mar 23, 2011
  • 2 more comments
  • Ginko
    Ginko Mar 31, 2011
    Hi.
    I was expecting a clarification request or a question. My answer was rejected and passed to a different experts.
    I do not understand the reason for asking the question to a different expert.
    On your request you will be assisted by a different expert.
    Goodbye.
    Ginko
  • Ginko
    Ginko Mar 31, 2011
    Hi John.
    No problem. I try to inform the users that when you ask to more experts you effectively pass the case to someone else, interrupting troubleshooting.
    I have done a number of Electrolux similar to your hoover, and the answer was targeted to your appliance model. Unfortunately I do not have access to Hoover technical documentation, therefore I did not provide diagrams.
    Probably you are right and the next expert may be able to provide more specific help and documentation.
    Ginko.
  • Ginko
    Ginko Mar 31, 2011
    ....I was talking about a washer dryer. You first test the thermostat. Parts like dryness sensor (if present), and electronic control are more difficult to be tested. If the washer is heating, then the element should be OK.
    See if anybody can find precise diagrams or service manual for this Hoover Washer. That will tell you how many thermostats are in use, and the precise location of the thermostats in the heating assembly.
    Good luck.
    Ginko.
  • Ginko
    Ginko Mar 31, 2011
    Good luck.
Takes too long to dry
Is it heating up at all? I just fixed my vision hd hoover 381 dryer by replacing the heating element. Email me if you think this might be you (matskm@gmail.com). When the dryer is running, feel the metal heater housing (carefully) on the back (silver bulge) if your model is like mine.
Jan 09, 2014 | Hoover VHC391 T-80 Dryer
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Dryer not heating Enough
Ceck the vent hose and vent. Make sure these are clear of obstruction. This is tipical of poor venting. The dryer can`t remove the moist air to dry the clothes properly.
Nov 14, 2008 | Hoover HDC6 Electric Dryer
Does not heat up when drying clothes
heating element is most likely shot.
good luck
please mark the post with a fixya
Feb 19, 2008 | Hoover Nextra HNWL 3126 Front Load Washer...
Hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Aug 14, 2007 | Hoover AL130 Front Load Washer
Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Nov 04, 2006 | Hoover Nextra HNWF 3135 Front Load...
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
