Question about Stoves 720EF Electric Double Oven
Can I download a Manual for a Stoves 61EDO cooker. I am specifically wanting to know how to use the timer. Thanks
  • 250 Answers
I have posted how to use the timer on the 720 on other solutions. Try that to see if it works.
Posted on Jun 04, 2011
Can you e mail me the manual for Stoves precision 1100 cooker
no
go google and type in--- user manual for stoves precision 1100 cooker --- and download the pdf version your self
Sep 26, 2016 | Stoves Ovens
Stoves 720G Manual
SOMEONE POSTED
However...I discovered the little buttons on the timer come out completely. So I used a cocktail stick to poke about inside the holes where the buttons go till the Auto mode light disappeared and the cooker went back to manual. And my oven works again as before.
Jan 04, 2015 | Stoves Ovens
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Dec 16, 2014 | Stoves 720EF Electric Double Oven
How do I bypass a faulty timer unit on a stoves 720ef cooker
Try taking the power wire that goes into the timer and the power wire that comes out of the timer and put them together not hooked to the timer and that should work. If that works you should solder them together and electrical tape them good.
Make sure the power is off when you do this so you don't cook yourself.
Dec 03, 2014 | Stoves 720EF Electric Double Oven
How can I reset my timer to manual on mylevc66w cooker
Well, not your EXACT cooker, but next one The lecv67, should be the same instructions.
Download here
http://www.leisurecooker.co.uk/Products/Download?filename=LEVC67.pdf
Page 20 and 21 refer to what you want.
Sep 16, 2014 | Ovens
Stoves newhome manual
Yes it's possible to disconnect the clock but must be done by a professional repair man
Oct 10, 2017 | Ovens
Lost manual
Hi,you can download the manual for your unit for free at;www.manualsonline.com or www.manualnguide.com.
Thanks and take care
Apr 19, 2010 | Stoves Premier 720DCa Dual Double Oven
Lost handbook for cooker. Cant remember which
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Faulty timer function on Stoves 720 EF
To take off the front button panel.
First power off the cooker, then remove the three right control knobs - they are just push on and push off. There are flats on the spindles matching contours on the knobs to ensure thay go back correctly.
Lower the top oven/grill front. Under the front button panel there are three screws going upwards. One at each end and one in the middle. Remembering how they are installed, remove them. The panel will now be loose but it is held in postion by two or three lugs which are along the top inside edge of the panel. They, from what I remember, hook into the inner panels of the cooker. I think you have to lift the lower edge of the panel towards you, to overcome the upward bend of the lugs.
The buttons for the clock are purely push fit and if you want they can be removed using a thin bladed knife.
I have to say that if you want complete access to the clock, I think you will have to take out the complete oven from the unit and take the top off, so be warned. Instructions of how the cooker is mounted are in the instruction manual.
Putting the front panel back I found to be fiddily - ensuring the lugs are located correctly, especially the one by the clock doesn't always want to work. In the end I left that one not positioned correctly, so in effect the front panel is slightly out at the left hand end.
Best of luck!
Jan 28, 2009 | Stoves 720EF Electric Double Oven
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Stoves 720EF Electric Double Oven Logo
555 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Oloyede Monsuru
Are you a Stoves Oven Expert? Answer questions, earn points and help others
